I have one and I don’t recommend the one I have. Here’s my empty one, purchased from tire rack that I don’t use anymore:
There’s a couple of reasons I don’t recommend them.
- They are pretty pricey to get them to hold 400lbs (preferably 500lbs) of wheels and tires. With air, wheel weights, tires, etc our wheel package is nearly 100lbs each in the 22” variety. And you’d need 2 to handle both sets at the same time.
- The rack is bulky enough that you generally have to put them up high. Which brings me to...our wheels weigh nearly 100lbs each!
- The rack causes some very minor flat spotting. It goes away once mounted and driven on, but overall not great for the tire. This is mostly because our wheels weigh so much...
Otherwise, I’ve previously used those racks with other wheels and cars. But they were usually half the weight.
I’ve since moved to these:
They’re much more flat against the wall and allows me more mounting flexibility due to the size and the individual mounts. Oh, they also cost less. They were $40 for a set of 4 vs $130 for the one above, although it looks like they’ve since increased the price.
Wheel Hangers Set - Wall Mount Tire Rack Alternative - Space Saving Wheel Storage for Garage Shed, 4 Pack
https://www.amazon.com/dp/B075SWH2VN/ref=cm_sw_r_cp_api_i_Rt1oEbYJRXCM8
