JRP3
Hyperactive Member
Even a light tap on the air brakes will make that noise.Wonder how much regen they're getting, though. I keep hearing the pneumatic brakes.
I used to live in a city with trolly cars and while having some benefits they are always complemented by buses because they only go where there are tracks and that's often a small percentage of the area serviced because of cost. That caused another problem they had to have a bus lane and a trolley lane so it took up a lot of space and because the trolley cant pass another one they clogged the system every time there was a problem and that's why some have suggested buses with the same propulsion system but with a small battery to be able to drive off the grid if needed and no rails needed. There are of course always solutions to problems like this if there is a will and some capital, personally i like some sort of skytrain(?) because it runs above and parallel to anything else.I think trolly cars make more sense.
So it's really not a quarter of the time that similar cells take. And since these are probably Toshiba Scib cells, similar Altairnanos can already recharge in about 5 minutes, and from deeper than 50% DOD.Toshiba has announced plans to develop electric buses that can perform a charge in just 5 minutes, which the company says is roughly a quarter of the time that similar lithium-ion cells take. There's a catch, though: to achieve these speedy recharges, the buses cannot drop below 50 percent charge
To say the least. maybe inductive power delivery would be better.Of course the overhead wires can be a bit of an eyesore.
They are more noticeable in pictures (esp. in the intersections where there are different lines that have to go in different directions). In real life, you get used to them and they become essentially invisible (basically filtered out of the vision).Of course the overhead wires can be a bit of an eyesore.
Another BYD sale to a Canadian city ...
BYD will supply up to 10 all-electric buses to Windsor, Ontario
BYD says its eBUS-12 can go as far as 186 miles on a single charge and can be recharged in as little as 30 minutes with BYD's own 600-kilowatt rapid charging system.
