Prototype rear lighted T under development: questions
Discussion in 'Model S: Interior & Exterior' started by artsci, Feb 17, 2014.
  1. artsci
    artsci Sponsor
    Timonium, Maryland
    Oznium is now working with me on a beta for the rear lighted T. The basic design will be similar to the front lighted T, but the size and curvature of the rear T is different so new injection molds will have to be made. We will use red LEDS and the PCB will incorporate a switch that's connected to the brake lights. When the rear lights are on, the T will also be on and when the brakes are applied the T will light at a brighter intensity, just like the brake lights.
    Installation will require drilling two very small holes in the rear panel under the T and making connections to the brake lights. As my goal is to make installation as simple as possible, I'm curious about connections to the brake lights. The obvious choice would be the LED strip over the rear window, but I beleive that would require removing the plastic trim around the lift gate. Does anyone know where the brake light connections may be in the lift gate and how we might be able to avoid removing the trim to access them? There's a black piece under the rear chrome appliqué that appears to be held in place with four screws. This piece holds the two license plate lamps and extends the length of the appliqué. I'm going to remove that this weekend to see what's there in the way of connections that might work. But I'm hoping someone else may already have knowledge of these connections and be able to provide some advice. Thanks!
  2. rekoh
    rekoh Member
    Minnesota
    Sounds interesting! I would think that the 'simplest' connection would be to install the lighted T -- drop down the wires to the license plate power supply. When you take things apart, you might want to look at that feasibility as well. It doesnt give the extra light when braking, but would be easily illuminated, and may be simpler to manufacture.
  3. artsci
    artsci Sponsor
    Timonium, Maryland
    As the license plate lights come on at night with the taillights that's a very good solution and one I'll implement if we can't trigger the T with the brake lights.
  4. wormhole
    wormhole Banned
    Westchester, New York
    Artsci,
    this is very cool although I've been working with my local SC manager on having the "T E S L A" light up on the chrome back piece that connects the backup tail lights...the challenge has been to laser cut the letters out, but he seems to have the wiring, lighting and the mold to fill in the lettering complete. Happy to make an intro offline as his wiring knowledge may come in handy if you want to PM me...
  5. artsci
    artsci Sponsor
    Timonium, Maryland
    Just sent a PM.
  6. artsci
    artsci Sponsor
    Timonium, Maryland
    Here's a photo of the piece I was referring to in the earlier post. I'll remove it this weekend to see what power connections are available to light the rear T.
  7. mknox
    mknox Well-Known Member
    Toronto, ON
    Sorry for the off topic question, but what did you use to color in the TESLA letters on the chrome strip? (can see it in your picture of the license lights) I've been wanting to do that but am unsure of what to use.
  8. tezco
    tezco Sig P85
    Colorado
    Here is a link to a thread that might prove useful: Center Cap Tesla T
  9. artsci
    artsci Sponsor
    Timonium, Maryland
    That was a kit of stick on letters sold by rogbmw. You have to PM him to order.
    Rick
  10. NigelM
    NigelM Recovering Member
    Sarasota, FL
    Mod Note: one post and resulting discussion including those who quote snippy comments, went here - snippiness. Please use the report function instead of reacting with your own snippy comments. Apologies to innocent bystanders.
  11. MoeMistry
    MoeMistry Local Vendor - SoCal
    Southern California
    Rick, from what I can remember, the screws you've pointed to on the black strip may not do much for you. Two are simply for the back up camera and it'll simply loosen it so it can be pulled out from behind. The other four will simply loosen the black strip which, if I remember, is attached to the chrome piece.
    Your best bet will be to remove the trim pieces. They're simply held in by a few strategic screws which are revealed once a few trim pieces "pop" off. Pretty simple DIY project. We've got a MS coming in today and tomorrow...I can try and take some photos for you when I get a chance.
  12. artsci
    artsci Sponsor
    Timonium, Maryland
    Photos would be great!
  13. artsci
    artsci Sponsor
    Timonium, Maryland
    The rear lighted T has been designed and is entering production now. First up will be a number of betas for testing on my car and one or two others. It will have circuitry for two levels of brightness: running and brakes on.
    Power will be supplied via the rear LEDS on the top of the lift gate window. Wiring will require drilling of one small hole each under the T and arch and removal of the plastic trim on the lift gate. I'll be doing a test installation and video with another owner in about 30 days.
  14. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    Great! I'll probably be interested in this too. I gotta get around to installing the front one still haha
  15. rekoh
    rekoh Member
    Minnesota
    I would be up for the Beta !
  16. artsci
    artsci Sponsor
    Timonium, Maryland
    OK, noted.
    - - - Updated - - -
    OK as well.
  17. Shumdit
    Shumdit Member
    SC
    I would be happy to beta test. I have bought all of your other projects so I might as well join in here too!
  18. artsci
    artsci Sponsor
    Timonium, Maryland
    Noted, as with the others.
    At this stage I'm not sure how many betas will be produced so I can't make firm commitments. SUPRKAR will be one for sure, as he has provided valuable technical info on these various projects. In fact, once we have the betas we'll be meeting at the Delaware supercharger to do an collaborative installation of rear lighted T and the camera switch, shooting video of the installations. If others want to join us there I'm sure it can be arranged.
  19. ABVA
    ABVA Member
    Northern Virginia
    ARTSCI, please count me in and let me know when is the meetup in Delaware.
  20. artsci
    artsci Sponsor
    Timonium, Maryland
    Will do -- I'll post here and on events when we get this scheduled. This will be in May no doubt.
