So quick backstory: I had a NEMA 14-50 outlet installed in my garage a little over 3 years ago as I had just moved into my new house and needed an outlet for my EVSE to charge my at-the-time Bolt. Used the outlet to charge @240V/32A with a Tesla Gen 2 UMC + Jdapter for over 2 years no problems. Then last year I took advantage of some state/utility rebates to upgrade to a Chargepoint Flex Home NEMA 14-50 plug-in version, and used that to charge my Bolt since last fall. In July of this year, I had Chevy buyback my Bolt due to the infamous battery recall and picked up a Model 3 and have been charging my 3 via the CP Home Flex and j1772 adapter that came with the car.
Starting maybe a week ago, I started getting "charge interrupted" alerts from the Tesla app (have my 3 set to charge at 11pm every night to take advantage of TOU pricing) 1-2 hours after it started charging for the night. I chalked it up to something going wonky with how the car and CP unit were trying to both handle TOU charging, as when I woke up the 3 was always at its target charge level.
Then last night I got another alert before midnight, so I went to my garage to see if something was up with my CP unit. That is when I smelled a plastic burning smell, and upon inspection of the NEMA 14-50 outlet I noticed some black soot marks above it! After shutting off the breaker, I saw that the CP unit's plug was starting to melt on 1 side. After much effort, I yanked out the outlet and one of the prongs looked charred and that side of the plug was starting to melt. Unscrewing the NEMA 14-50 receptacle, I saw obvious signs of melting wiring (the red wire's casing was completely burned and I could see exposed wire). Seems like I came very close to having a fire break out and potentially burn my house down!
I think I definitely need an electrician to come out to look at the outlet, but trying to figure out what went wrong. I charged my Bolt fine for almost 3 years using the outlet (probably some $10 Leviton one from Home Depot....local electrician installed it), and 6 weeks after I started charging my Model 3 with it, this happened. The Bolt and SR+ 3 both charge at a maximum 32 amps, so pretty sure the 3 was not pulling any extra juice from the wall compared to the Bolt. Also, if it was a poor install job, problems would have probably surfaced sooner than 3 years, right? I charged my Bolt (and then Model 3) at least 3-4 times a week using that outlet since it was installed in 2018.
Until an electrician looks at it and installs a new receptacle (ordered a Hubbell unit from Amazon) I'll have to resort to 120v trickle charging and probably some sessions at a local Supercharger as well.
