PSA - left turn signal doesn't reset - defective steering control module
voip-ninja
Give me some sugar baby
Mar 15, 2012
4,533
5,607
Colorado
Just a PSA here, apparently a large # of vehicles were manufactuered somewhere in the 99x, 100x VIN series that have a defective steering control module.
This has been discussed recently in the "other" forum but owners here might want to be aware of the problem so if they are stung with it they know how to communicate the problem to Tesla.
The issue is that the left turn signal never resets. So, if you do the "half push" to get three blinks or you do the continuous push down of the left turn signal and expect it to reset after completing a turn, it never does.
You can check this before pickup even without driving the car. Half press the right signal to see how it works, it blinks three times then stops. Now do it on the left side. If it never stops blinking you have this problem. Up to you at that point how to proceed (making them fix it before pickup, insist on mobile service, etc.).
It requires a new part to repair as the one the car was built with is defective.
This is not being checked before delivery so the first time you might discover it is at drive off and nobody loves going in for service immediately after taking delivery of a brand new car.
Fortunately for me I was able to get them to commit to having a mobile service tech come to my place of work to replace the part once it arrives at the service center.
I felt something was off so I just decided to not use my turn signal anymore. :D
I'm in the 55,000 range though.
I will check again when I get my car back from PPF. Did you get your car already?
I picked my car up yesterday but don't have PPF/ceramic appointment till early November as that was first availability at the shop I wanted to use.
Maybe shop will do you a solid and just PPF the front bumper for now. That's where most of the action happens.
Glad you didn't see anything severe enough to reject the car. I feel problems are overstated even though my own wasn't pristine.
The only thing I've noticed in the past 24 hours is that one of the rear doors is aligned a little below the "ideal" line, the other one is spot on.
I am worried about bumper highway rash too but not sure there's much to do about it... there's no way I'm getting into that shop for another month. I suppose I could have PPF done somewhere else and just have them do the ceramic, but they were expecting to do both.
My car with VIN 64xxx has a similar issue, although I can sometimes get the 3-blink to work by only touching the stalk *very* lightly.
Some users in this thread have reported this as well:
Model 3: Turn Signals... ARGH!
Whats fun is doing a lane change with auto pilot on. After changing to the left lane it blinks about 12 more times before it's finally able to turn it off. It seems to try to turn it off a few times because I hear what I can best describe as a half blink.
We also had this issue, vin 995xx, and they replaced the steering control module earlier this week. We mentioned that others also are having the same problem, but the service rep hadn't heard of this issue yet.
i m 56xxx and noticed the left turn. It works fine with the right turn signal. Does Tesla has a fix for this issue? I also noticed my right turn will not stay on for more than 3 blinks. If you use the auto lane change, it will stopped half way through the change and snap back to the lane.
To fully engage the signal you need to push the stalk down firmly. It’s not clear from your description if your signal is actually broken.
