The sticker doesn't know. The recommendation is for the vehicle. The sticker tells you what the tires have to be able to handle.
The responsibility is that you must find tires that fit and are the right size (more than just fit on the wheel and fit in the wheel well, they need to have the right diameter and revs per mile to keep the speedometer within accuracy limits and not get RPMs too high or too low for the gearing) and have a max tire pressure equal to or greater than the door sticker.
If the door says 45 and the side of the tire says 44 then your tires officially aren't fit to be put on that vehicle and you would be liable for any damages, wreck, tickets by police, and such for running substandard equipment.
Just make darn sure your tires have a number for max PSI equal to or greater than what your car needs.
