This is the very simple common sense and decency point.
No complex flow chart — just simple decency.
People who pretend not to understand this or think it is more complicated are either bizarrely selfish or just stupid
the one that absolutely needs it to reach his/her destination should be given courtesy preference.
It seems that there are relatively few folks here that disagree with this premise and are of the
"screw everyone else" mindset... (but there are indeed a few).
I applied the emphasis as I did for a reason: the premise is that it's something to be
given... not
taken.
All the Teslas do NOT need any extra charge to get home
Here is where the larger disagreement seems to be. For all the reasons previously pointed out, this blanket assertion may not hold true (person has to travel some distance after work, they have a 100 mile commute in the cold in a 60, etc...).
For example, there's a guy here who drives 120+ miles after work on some days in his Tesla. In the cold weather we get, that can burn 200 miles of range. The 208V/40A charger we have her only adds ~24 miles per hour.
Hence, the blanket assertion is something that simply can't be known for the vast majority of situations, and is hence invalid.
All Leafs and I3 absolutely do need on a cold day.
Again with the blanket assertions.
Average US commute distance: 16 miles. And 92% of commutes are
less than 35 miles
2016 Nissan Leaf
Range: 107 miles.
Even in the cold the Leaf should easily get the vast majority of people to and from work without charging at work at all. As eould the 81 mile i3. And that's not the new 2018 Leaf w/ 150+ miles range. Or the i3/REx or a Volt. Once again, this blanket assertion is invalid.
The point is, circumstances can, and do, vary. Making blanket assertions as to when to
TAKE charging from others when you can't know all of those circumstances is every bit as much of an entitled action as is the discourteous person who hogs a charge station.
