Pull Over Safely, Restart Car to Drive
Discussion in 'Model S: User Interface' started by brianman, Feb 4, 2014.
  1. brianman
    brianman Burrito Founder
    #1 brianman, Feb 4, 2014
    Has anybody else run across this message before? It happened when I floored it while entering a freeway on-ramp. Fortunately, I was in the middle of nowhere (no traffic behind me).
    Notice the orange and red gear letters.
    Upon restarting the 17" and then putting the car into drive it cleared itself and the car behaved normally from there on out.
    For what happened next, look here:
    PocketDyno, Sig P85 A after 23k miles
  2. patp
    patp Member
    Canada
    Yep. Check with Tesla as after 3-4 times they finally had to replace my whole battery pack. Do you have a Sig?
  3. brianman
    Eep! And yes.
  4. PeterK
    PeterK Model X & 3 Owner
    Cambridge, MA
    Brianman, perhaps it's a message that type A personalities and type A batteries don't mix. Time to move on to a type B?
  5. lolachampcar
    lolachampcar Well-Known Member
    WPB Florida
    Nice one Peter!
    I've set up next to a bud in a Sept. delivery S85 to run him. I made sure he moved first before moving to keep from jumping him. Both times we tried this (back to back) his car did exactly the same thing. The throttle was non-responsive and the car simply shut down until he stopped and cycled through park. It would not repeat with just one car twenty minutes later at the service center. We have yet to do it again to confirm but I suspect something in his car was upset about something coming from my car (FM???).
  6. zax123
    zax123 CDN Model S P308
    Candiac, QC, CAN
    @lola,
    Are you serious? Do you honestly think there's some kind of wireless interfere from one car to the other? That would be completely insane!
  7. Chipper
    Chipper Active Member
    Chattanooga, TN
    Personality or Battery??:tongue:
  8. Robert.Boston
    Robert.Boston Model S VIN P01536
    Portland, Maine, USA
    I had a similar error message and red-out of the PRND on the dash, in a similar situation. I had just punched the accelerator from a low speed, and the car completely lost power. In my case, Tesla replaced the Power Inverter unit. Like you, I have an early-production car (Nov.2012).
  9. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    I guess that means that everyone with an 'A' pack doesn't need to hunt for tow-hitches to drive over any more. Just keep punching it over and over until it craps out on you and then go get your new 'B' pack and 120kWh supercharging!!!
  10. brianman
    Let's not jump to conclusions just yet. ;)
  11. Zextraterrestrial
    Humboldt/Los Altos
    ya, this doesn't seem to work :wink:
    just dropped off my second set of 21"s to get the tires flipped and my 19" fun tires with ~200mi need the same thing done.
    I think I have well tested the punching it repeatedly.
    never had any sort of drive failure or error msg related
  12. lolachampcar
    WPB Florida
    Zax,
    Yep, I know. We really need to reproduce the problem as it just could not be that I was next to him although it happened twice back to back and then would not do it 20 minutes later at the service center (when I was not next to him). He's out at the airport and we've been talking about lining up again.
  13. jerry33
    Texas
    I think you'll need someone with an "A" personality to punch it.
  14. PeterK
    Cambridge, MA
    About your personality or your battery? :)
  15. strider
    strider Active Member
    NE Oklahoma
    My wife got the same message except the car would not not move after a restart. Even did a hard reset by pulling the yellow fuses. No dice. Car stayed powered up and HVAC still worked. Tesla towed it and ended up replacing the inverter. It also showed this: IMG_00000058.jpg
  16. zax123
    Candiac, QC, CAN
    You got the P40!! You should keep that car safe, it'll be worth a lot sometime in the future. :)
  17. deonb
    deonb Supporting Member
    Redmond, WA
    Now the question that will bug us until the end of time...
    Does the software actually contain artwork for a single P40 bitmap, or are the P and 40 two separate bitmaps?
    It has pretty profound implications.
  18. N4HHE
    N4HHE Member
    Madison, AL
    A Performance 40? :)
    Yup, I'd say the computers were not happy about something that day.
  19. brianman
    0-60 in one full charge
  20. strider
    NE Oklahoma
    It was still showing the correct range based on an 85kWh battery. But yeah, it really tossed its cookies that day. Worked perfectly before and after -<shrug>-
