I wanted to share my experience pulling a new Tab 400 boondock trailer on the Model Y. The Tab 400 weight is ~3000k, add gear and other items and you are near the 3500k limit. The tongue weight is ~325, once you add a full propane tank you are near the 350 lb limit. So for this exercise we assume we are very near maximum limits. Trailer is in a teardrop shop for maximum aerodynamics (FYI the boondock is 17 inches higher than the regular tab 400 and higher ground clearance, I expect the regular to have slightly better range). Using the manual limit of only 3/4 inch rise, the trailer was slightly lower than level (just barely).
Trip:
Range used to supercharger (going there): 300 miles (31 remaining)
Range used to campsite: ~178
Range used to supercharger (from campsite): ~175
Range used to home from supercharger: 323 (8 remaining)
Even in a fairly good aerodynamic trailer, the max weight pull pretty much kills range. I was only getting slight over 1/3 of my range. I would say the comfortable range would be ~100 miles to tow at full weight. In bad weather/wind or colder temperatures I doubt I could make it to the supercharger to home (and maybe not even going there).
Pulling was an absolute breeze though. So easy to accelerate and go up and down hills. Very deceptive to use more energy on making a hill climb since you do not feel the resistance.
Hope this helps everyone in making some trailer pulling choices!
Trip:
- 162 miles total
- 331 range on full charge
- ~100ft change in elevation (downhill to destination, uphill home).
- 70-80 degree weather
- low wind (none/low going there, light crosswind coming home)
- Supercharger 105 miles from home and 57 miles from destination (going back home)
- Only drove at maximum speed recommended by trailer - 60 mph (some areas were as high as 75, but never went higher than 60)
