Purpose of speed in circle need to speedometer?
Discussion in 'Model S: User Interface' started by HX_Guy, Dec 28, 2016.
  1. HX_Guy
    HX_Guy Member
    Phoenix, AZ
    Can someone please tell me what the purpose of the circle to the left of the speedometer, which also shows the speed, is?
    I noticed when you get the cruise control, the number in the circle shows what your cruise is set at, but when the cruise is off...it reads the same as the speedometer or disappears completely sometimes.
  2. grichard
    grichard Member De-Luxe
    St. Louis, MO
    It's the speed at which the cruise control will engage if you pull the stalk toward you.
  3. HX_Guy
    HX_Guy Member
    Phoenix, AZ
    Hmm...that's seems, redundant. Wouldn't it be logical that whatever speed your are currently traveling, would be the speed that cruise would set at if you pulled the stalk?
    So I guess it's safe to assume that if the circle is not there, like in the top photo, then cruise cannot be used?
  4. andrewket
    andrewket Well-Known Member
    It makes sense when you have AP. Less so without those features.
  5. HX_Guy
    HX_Guy Member
    Phoenix, AZ
    How does that circle work/interact with AP?
  6. mrElbe
    mrElbe Active Member
    Stouffville, ON Canada
    Also when the circle appears it means that Cruise control is available.
  7. mal_tsla
    mal_tsla Member
    Austin, TX
    I have cruise control default set to +5 mph from speed limit, so in your situation above the number in the circle would be 50. It would continue driving at 35 if there's a car ahead or speed up to 50 if the road is clear.
    I agree in the situation cited above its a little redundant. But it's hard to choose between consistent and not redundant when designing interfaces sometimes so I get where Tesla was coming from.
  8. NOLA_Mike
    NOLA_Mike Grouchy
    Hammond, LA
    Not necessarily. I believe if you had a previously set speed that you disengaged to slow down or stop it would display the previously set speed such that when you pulled the stalk it would "resume" to previous set speed.
    So, if it matches the speedometer then it will set the current speed. If not, then pulling the stalk towards you will "resume" to the speed shown in the circle.
    Mike
  9. GMDC
    GMDC Member
    Switzerland
    If you don't want it to resume to your previous speed, say it was 75 so it's in grey. And currently the max speed is 45 like in your pic. I believe you can pull the cruise control stalk for a few seconds to make the CC speed (in the circle) match the max. Speed detected by gps or signal read by the camera.
