  • We are looking for another podcast participant who can act as a lead co-host to join the TMC Podcast. If you are interested in participating please see this thread.
Pushing the park button won't open door handles
P100D_Me
1,083
1,093
Australia
Hi All,
Maybe this issue is since my last software update to 2022.8.10.6 (I'm not 100% sure but it is only recently). When I am parked and want all four door handles to open pushing the button on the end of the shift lever doesn't do it like in the past. I can use the MCU screen to unlock them all or the key fob but the 'Park' button no longer works.
I have tried an MCU reset just in case but it made no difference.
Has anyone else run into this problem?
TIA
There is a setting for Driver Door Unlock Mode. This can be used to only unlock the driver door versus unlocking all the doors. I think you can find that under Controls > Vehicle > Driver Door Unlock Mode.
Sounds like maybe that setting has gotten changed?? That's where I'd start.
Reactions: gillmj24
P100D_Me
1,083
1,093
Australia
Ok I figured out what it was for those that run into this, the problem is Tesla bugs.
If you have 'PIN to drive' active then it stops working even if you've done the PIN and turned the car on, as soon as I disabled that then the button on the end of the shift lever unlocks all doors again.
As I said I don't know if this is a recent issue with 2022.8.10.6 as I only activated PIN to drive not long ago.
