Putting some numbers on the factors that affect range
Discussion in 'Model S: Battery & Charging' started by ChadS, Jan 27, 2013.
  1. ChadS
    ChadS Last tank of gas: March 2009
    Redmond, WA
    On good days, you can definitely make it if you keep your speed down. But part of the problem is, like AWDTesla hints, that you can't predict the bad days - because a day that looks like a good day might have, say, surprise headwinds.
    If it was a nice day and I was doing it once I might try the 200 mile trip. But I wouldn't do it on a regular basis (at least not in a 70) without a known place to stop along the way. Not all leave as much buffer as I do; but I want to make sure I never run out and in fact I don't even want to worry about whether or not I will make it while I am driving. If you do fall short, it usually won't be by much; so if there is a charger you can count on that is, say, 75-80% of the way you could use that only in emergencies, and you shouldn't have to be there too long.
  2. hiroshiy
    hiroshiy Supporting Member
    Tokyo, Japan
    I think your rated range is 240 miles on full charge, correct? In summer, without heat and without significant headwind, you can do that trip without any problem as others noted. However in 32F you will get minus 20-30% less rated range:
    20% 200 miles
    30% 184 miles
    So, if it's really cold like less than 32F, you won't reach 200 mile destination. If it's a bit warmer, you need to reduce the speed to 65 or 60 mph to achieve 200 mile trip. If I were you, if it's snowing I'd find a charge in between absolutely. If it's not, research emergency charging spots in advance, start with 60 mph with AC at comfortable setting. If you think it's cutting close, either you turn off your AC (if weather permits) or stop to charge. Once you are confident that you can reach destination you can speed up to 70 (but I don't recommend 75).
    • Informative x 2
  3. f1tifosi
    f1tifosi New Member
    Does anyone know if the new ('17) Model S front fascia has improved the vehicle's drag coefficient and thus contribute to a higher range? Range ratings have not changed on the website but is it a matter of time someone looks at the new cars efficiency in carving through wind?
  4. tagpats
    tagpats Member
    Falls Church, VA
    The Tesla website does not show it, but I've read that the refreshed 90 is 303 rated miles of range. None of the news articles I've read mention the 70, but if the new front is the reason for the increase then it seems reasonable that the 70 would also realize a slight gain as well.
    Tesla’s updated Model S just broke an incredible barrier for EVs
  5. dweeks
    dweeks Member
    Flagstaff, AZ
    I have a 90D...took delivery a month ago. I accepted the car, and drove it home from the Scottsdale service center, and that night did a range charge, as I had a long trip the next day.
    303 miles. But that was the first and last time I have seen 303. Most range charges now give me 297-298 miles.
  6. X Fan
    X Fan Supporting Member
    Naples, FL & Cary, NC
    Longer trip to Asheville via Charlotte but North Charlotte supercharger would clearly be of benefit....
  7. ZBB
    ZBB Emperor
    Scottsdale
    The Model S configurator shows the refreshed 70 (Rwd, not D) with 234 miles of range. The pre-facelift was 230...
  8. Tony8489
    Tony8489 Member
    I have had my S90D for 2 months and 4499 miles. ChadS' speed and altitude factors have been reasonably accurate for the 3 trips to Mammoth during that time, the last one coming home via Yosemite.
    I looked at Matteo's online calculator but it has not been updated for the chargers opening in 2016. These include Burbank (surrogate for home, just 3 miles away), Mammoth, Fresno and Buttonwillow.
  9. Kensiko
    Kensiko Member
    Quebec, Canada
    Really interesting thread. We had a similar summary on PriusChat of how to minimize consumptions, it's a bit different but the idea is the same.
    What about tires guys? Do you all have recommended Tesla LRR tires ?
  10. DrManhattan
    DrManhattan Member
    Los Angeles
    This is not perfect math, but I did my first road trip in the 60S and my furthest Supercharger distance was 165 miles, and I had about 10 miles remaining. It was about 100 degrees out, and I drove 85mph most of the way. I feel if I keep it to 80 or below, I can do 180 miles no problem depending on elevation/weather of course.
  11. Kensiko
    Kensiko Member
    Quebec, Canada
    Hey can you tell us the speed for supercharging a S60 with S75 battery ? What is the power draw when close to 100% ?
  12. DrManhattan
    DrManhattan Member
    Los Angeles
  13. ldgrmnmc
    ldgrmnmc Member
    Pike Road, AL
    I apologize that this has been probably answered multiple times, but with all other variables steady, will my S70D get better range on long interstate trip with or without extensive use of autopilot? Thanks
  14. mblakele
    mblakele beep! beep!
    SF Bay Area
    If you try to beat AP on efficiency you probably can: you have better sensors and more computing power. But if you don't make any special effort, AP will probably be more efficient than you.
  15. jerry33
    Texas
    If you have enough practice, you can beat autopilot every time. The key is enough practice so that doing the efficient thing doesn't require much thinking on your part. All automated systems try to keep the same speed, so they use extra energy to do this. You can slow down and speed up when appropriate. This isn't a skill you learn in a week though.
  16. Kensiko
    Kensiko Member
    Quebec, Canada
    Do you have driving tricks to get the best efficiency ? Ex staying around 20 kW ? Accelerating quickly or slowly ? I would need to check the rear motor efficiency curve for my S60.
  17. jerry33
    Texas
    The general rules I use are:
    1. Keep some air in your tires and be sure they are properly aligned. Low air pressure really increases rolling resistance--even two or three psi are noticeable. (Not to mention that lower air pressure makes the wheels more susceptible to potholes and other impact damages.)
    2. The slower you accelerate the more efficient you will be. Use the power metre to monitor your acceleration. Don't bother with the energy graph, it's too far behind real time to help. (The way the power metre has changed in 7.x for AP cars is just awful for this because the first marking is at 75 kW. If you are using 75 kW of power, I sincerely hope your eyes are on the road, not on the instrument cluster.)
    3. The longer it takes to come to a stop, the more efficient you will be. Be light on the regeneration whenever possible. At stop signals, it's often possible to stop slow enough that the light turns green before you reach it. (Time spent waiting for the light to change does not get you to your destination any faster--although many drive as if it does.)
    4. The higher the speed you cruise at, the more energy is wasted by just pushing air. Five mph makes a noticeable difference in energy usage but not in elapsed time.
    Example: A 500 mile trip at 65 mph takes ~7:45, at 60 it's ~8:20. To each add thirty minutes for the extra time spent at lunch (while charging) and 1:15 for charging (Total charging time will be ~1:45). Convert to minutes it's 570 (9:30) vs. 605 (10:08) or ~6% difference in overall travel time. This is actually the worst case because by driving more efficiently, the non-lunch charging stops will be slightly shorter (I don't know how to accurately calculate that.) Bottom line is that either uses up about a day, so the extra speed doesn't buy you anything (other than maybe some range anxiety).
    The plan on a trip is: Start with a range charge. Then at each non-meal stop charge only enough to get to the next charging stop plus a bit extra just in case. At meal stops charge for the entire time you're there. This method reduces the amount of charging time that you're doing nothing but waiting. Last year, driving from DFW to Seattle, most of our non-meal stops were 15 minutes or less and the car was usually ready by the time we got back from a pit stop. Note this is for travel in moderate or hot weather. Cold weather will increase the energy usage resulting in longer charging times.
    Note that if you are going for shortest time, rather than for best efficiency, then drive as fast as you can between charging stops. (You can use EV Trip Planner to get some numbers for this.) I prefer to go for most efficiency because it's more relaxing which makes the trip more enjoyable.
    5. Losing a few mph going uphill will make you more efficient.
    6. Gaining a few mph going down hill will also make you more efficient, but watch it because there is a point at which you're just using the additional speed to push air rather than gaining distance from it. There is a point where the amount of energy you lose by pushing air is greater than the inefficiency of regeneration.
    7. Sometimes it's possible to choose a route that is more efficient. This works best on a route you travel frequently as you can become more efficient as you get to know the route.
    8. A route with fewer stops is almost always going to be more efficient than a route with multiple stops.
    9. Road surface makes a difference (not that you can do much about it except choose a different, possibly smoother road).
    10. You almost always get better efficiency on roads that you travel regularly rather than on unfamiliar roads.
    11. On vacation trips, up the tire pressure to compensate for the extra load and speed.
    12. On road trips, occasionally check the trip graph to see how you are doing compared to the estimate.
  18. Dennisj00
    Dennisj00 Member
    North of Charlotte, NC
    My dad taught me in the 60s to drive like I had an egg between the accelerator and my foot. Works pretty good with an EV. We've had 2 Leafs since 2011 and now with the model S, I'm getting 105-120% efficiency in Teslafi and still having fun driving it. Wife isn't, she treats her badly!
    I've been really surprised and pleased that range isn't affected too differently between driving at 50, 60 or 70.
    • Disagree x 1
  19. scottf200
    scottf200 Active Member
    Chicagoland ModelX S603
    I woefully misjudged how much extra range I needed on a leg of a trip a couple weeks ago when it was 16F. It was a rural 55 MPH road and I ended up driving 40 MPH on 1/2 of it. Info: Model X P90D. 2 adults and luggage. 45 lbs in 20" tires. No rain/snow. I was traveling from Macomb, IL to the Normal IL Supercharger which I've done several times. It is 106 miles and I left Macomb with about 135 miles (via a 14-50 plug). From past experience the built-in Tesla Trip Planner *always* wants me to travel southeast to Springfield IL regardless if I could make Normal. (seems to want to do this even if I would have 10% left!). I would *love* a way to force it to go to a specific supercharger so you could watch the trip graph and your battery percentage and leave when it was at 10% (summer) or 20% (winter).
    Wanting to learn more and contribute so others could use Tesla data for tools or charts...
    I used Model S data via Model S | Tesla and the Range Per Charge area to gather data for all the listed cars at different temps (90F A/C, 70F, 50F heat, 32F heat, 0F heat) and speeds (55,60,65,70). I wish Model X data was available.
    My spreadsheet also has some tabs where I used 3rd Order Polynomial Trendline formulas to generated data between 0F and 90F for the different speeds. That formula was new to me. It is standard and all over the internet.
    Link: Temp effects Tesla Model S part 2
    Here are the results grouped by MPH (55,60,65,70) where the green is as it taken from the Tesla page:
    i<dot>imgur.com/qcaMN4N.png
    Here are the results grouped by Model S (60, 60D,75,75D,90D,P100D) where the green is as it taken from the Tesla page:
    i<dot>imgur.com/PHISLOP.png
    i<dot>imgur.com/3kQ9yED.png
    <snip>
    • Helpful x 2
  20. FlatSix911
    FlatSix911 Porsche 918 Hybrid
    Silicon Valley
    Scott, thanks for sharing your range data. :cool:
    I have found that you can use the Model S range tool by subtracting 10-12% of the range for the Model X.
    Other factors to increase range ... maximum tire pressure and seat heaters vs. cabin heat in cold weather.
