PV for battery maintenance.
Discussion in 'Model S' started by cadethoerk, Jul 10, 2012.
Tags:
  1. cadethoerk
    cadethoerk Member
    How about including some PV cells in the pano roof to cover the battery maintenance electrical draw? That would keep the pack from ever reaching low volt damage. It would also look cool to see the PV cells through the sun roof. PV cells are getting so cheap and their efficency climbing every year. You could leave your car in long term parking for ever and that battery level would never drop. I don't know what the battery climate control draw is, but you might even have a little left over to charge the pack.
    What do you think?
  2. ElSupreme
    ElSupreme Model S 03182
    Atlanta, GA
    Unless you park in a garage.
  3. doug
    doug Administrator / Head Moderator
    SF Bay Area
    And if you're parked long enough that you're worried about loss of battery capacity, you probably should be plugged in.
  4. vfx
    vfx Well-Known Member
    CA CA
    See Nissan Leaf, Fisker Karma
  5. brianman
    brianman Burrito Founder
    Specifically, see the owner review video where he does the math. It was something absurd like 500 years of leaving the car parked in 100% sunshine (read: not Earth) to recoup the cost of the solar cells.
  6. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Solar cells on the roof of a car simply cannot produce a useful amount of electricity. It's too small an area.
    Anyone who puts solar cells on the roof is just doing "faux green" (looking at you Henrik).
  7. MikeK
    MikeK R#129, TSLA shareholder
    San Francisco Bay Area
    I figure they can probably produce enough to ventilate the cabin, and that's about it.
  8. Citizen-T
    Citizen-T Active Member
    Raleigh, NC
    Someday they will probably get cheap enough to make sense, but not this day.
  9. Doug_G
    Ottawa, Canada
    That's not really the issue. There's not enough energy received from the sun on an area that small.
  10. doug
    SF Bay Area
    There's enough power to run a fan to circulate some fresh air in the cabin, but that's about it the only useful function, and you only need a relatively small panel for that.
