I don't see much discussion on this topic.
I'm exploring the energy export option since my PW's charge exclusively with solar. If I enable "Everything", the PW's start exporting at nearly 10KW once peak starts. I set my reserve to 50 and monitored the progress. The PW's continued to export at this rate until they hit the reserve, then the gateway started drawing power from the grid. Is this expected behavior?
I imagined the system calculating the amount to export to ensure the PW had enough energy to make it thru peak before hitting reserve to avoid drawing from the grid at peak times. Instead, it just energy dumped until reserve was reached, then pulled from grid.
Does it eventually learn?
