If you want to combine everything onto one phase, you should get a second Powerwall, both to supply the added load from the water heater and also to absorb the added solar.
Yes, that would be nice. But I don't have another $12k around (AUD)
Even if you consolidate to single phase, you should keep one solar inverter outside the backup gateway. Today, my understanding is that one Powerwall really can't handle 10kW of solar during backup operation. In theory, they could improve the firmware to handle that case well (batteries low, but solar output exceeding Powerwall inverter power handling), but the solar inverters would have to have working proportional curtailment.
I don't know what kind of hot water system you have, but I assume it's a large storage tank that is designed to heat during off-peak and just coast through the rest of the day. Personally, I feel the best hot water solution when you have a large solar system and battery for self-consumption is a hybrid heat pump water heater. However, I don't know if they are commonly sold in Australia.
We have A geothermal heat pump that is used for heating and cooling our home and for hot domestic water. Radiant heating uses a heat exchanger inside our domestic water tanks. Very efficient and in the summer, heat from air conditioning the house goes into the domestic water so to some extent one or the other is free.
On the other hand, the nice thing about resistance heating water in large tank is that you can dump excess power to it when it is available, not when the hot water is needed. It does not care if the power is intermittent. When we lived on a sailboat with a single 15 amp 117V breaker, running the AC water heater was always a problem as if we were cooking, drying hair, ironing or using a space heater, the combination of hot water and anything else would blow the breaker and one would need to go out into the cold and rain and reset it. I designed and built a demand controller that would measure the instantaneous AC current being used by the boat at any given time, and modulated the current going to the water heater, using a triac, so that the total would be just below 15 amps. There was also an alarm if any combination of uses started to exceed the limit. To keep the lights from flickering and minimize RF interference, I used a zero crossing detector to either let a whole 60 Hz cycle through or not. Worked great and we had hot water from then on. I don't know if such a commercial device exists, but there are probably several situation where it would be handy. i don't see why your water heater needs both legs to work. Could you not heat twice as long with half the power?
I went Sanden heatpump, ditched the controlled load circuit, and programmed the Sanden to come on at 11am, drawing directly from the panels as part of the house load - and backed up by the battery as well. It runs for 2 to 3 hours, pulling 1 kW - Almost exactly one quarter the kWh the old electric element water tank used. Its more expensive than a new old-style HWS, but even accounting for the cost of power as foregone FIT @ 11.1 c/kWh, it still pays for the difference after around 4 years.Thanks for all of your help. Yes, we currently have a big 315L, which runs on off peak. Looking at a heat pump system in the future as it’s way more efficient!
Nice!
I've looked into the Sanden units also. Are they easy to program? We'd like to get rid of the controlled load also (Free a bit of space in our meter box, since we have a separate "Smart" meter for the extra load)
I’m just now looking at getting a Sanco2 unit and I’m curious what you think about yours now, 4 years later? Any issues or regrets?Dead easy to program - the controller allows you to set a 'blackout' period, a 'start hour' and a 'finish hour', for when you DONT want it to come on. For normal non-solar houses, this is to enable you to prevent it coming on during peak and shoulder cost periods - effectively do what the controlled load circuit is trying to do, but adjustable by you. For our solar home, I set it to NOT come on from 5pm through to 11am - so after we have showers etc at night and then the morning, by 11am the thermostat is telling the unit it really needs to kick in and heat up, so it does until thermostat says stop a few hours later. As a bonus, because it is heating during daytime rather than during night, it has warmer air to work with, so runs for a shorter time.
