Q3 2018 Vehicle Safety Report
Discussion in 'Autopilot & Autonomous/FSD' started by strangecosmos, Oct 4, 2018.
  1. strangecosmos
    strangecosmos Non-Member
    The Prime Material Plane
    #1 strangecosmos, Oct 4, 2018
    Tesla just released its Q3 2018 Vehicle Safety Report:
    While this is a good start, we need more data. Tesla should compare the crash rate of miles driven with Autopilot engaged on freeways vs. the crash rate of miles driven with Autopilot not engaged on freeways.
    It’s conceivable that the set of non-engaged miles would be biased towards more complex and more dangerous situations. So, another way would be to compare the freeway miles of customers who have purchased Autopilot and those who haven’t. Both metrics should be presented.
    Also, HW1 Autopilot and Enhanced Autopilot statistics should be broken out independently.
  2. caligula666
    caligula666 Member
    Switzerland
    The report lacks depth to really understand what they mean. AP is less likely used on local and city roads, yet the likelihood of an accident per km is much greater than on highway where AP is typically used. So is this highway data only? This would imply cars would somehow internally have dedicated counters to track what distance was driven on what type of roads? Or that there is a huge bias.
  3. strangecosmos
    Yes, I think there is a bias. Benchmarking Autopilot miles — predominantly driven on freeways — against all others miles is a skewed comparison. I believe most crashes occur off freeways.
    The ideal would be for Tesla to turn over all its raw data to a trusted third party who can conduct an independent analysis.
  4. caligula666
    caligula666 Member
    Switzerland
    Agreed 100%
  5. strangecosmos
    I emailed Tesla and asked them if they would release more information. Worth a try.
  6. S4WRXTTCS
    S4WRXTTCS Well-Known Member
    Snohomish, WA
    Agreed, but there also has to be a separation between TACC only versus AP.
    My rationality is that TACC only drivers are the best drivers.
    We're going to win!!
  7. Tam
    Tam Well-Known Member
    Visalia, CA
    #7 Tam, Oct 5, 2018
    Theoretically, just like GM Super Cruise, Autopilot can only be used on limited access freeways and not off-freeways (as warned by owner's manual.)
    In reality, that is only true for GM Super Cruise but not for Autopilot.
    GM Supercruise does not work off-freeway but Autopilot does work in many situations even in off-freeways.
    Tesla was scolded by NHTSA for not geofencing enough and allowing Autopilot running during the Florida fatal accident because that highway although with a posted speed limit of 65MPH has intersections and is not a true limited access freeway.
    Recent Consumer Reports prefes GM Super Cruise because it would be off for the above Tesla accident, off-highways, local roads, construction zones... It rewarded GM as the first place winner while Autopilot lost to GM even though it would still continue to work in those situations that the first place winner can't even work. (Consumer Reports thinks being conservative that does not work in many places means safe.)
    So to answer the question: No. The data is NOT for highway data only. This is no first place winner GM Cruise. This is second place loser that works almost everywhere.
    The criterion here is "Autopilot engaged" and it is used in almost all over the places.
  8. Tam
    Visalia, CA
    No questions about it!
    As it says in the manual, it "is primarily intended for driving on dry, straight roads, such as highways and freeways. It should not be used on city streets."
    Currently, Autopilot takes the easy job and human takes the hard one.
    But I think this is not about bias or unfair that who does a "straight" easy job and who does the more complex job.
    Because without Autopilot, there's only one to take both the easy and hard jobs: human and there wouldn't be consideration about bias or fairness.
    It's about: Is it safer to have your car with Autopilot where if you want, you can use it or a car with no options of using Autopilot at all (such as GM Supercruize.)
  9. caligula666
    caligula666 Member
    Switzerland
    I get that but the point remains: there is no way of knowing that based on the statistic Tesla computed. It is a BS stat at best.
  10. Tam
    Visalia, CA
    Before this, NHTSA cited the stat that Autopilot equipped VS. non-Autopilot equipped cars.
    That is regardless whether an owner would use the Autopilot or not or even whether the owner bought the Autopilot or not.
    So, now the criterion of "Autopilot engaged" is better than the above.
  11. strangecosmos
    Actually, NHTSA just looked at the crash rate for all Teslas before and after Autopilot was released. But the IIHS looked at Teslas with Autopilot hardware vs. those without and also found a reduced crash rate.
