QI Wireless Phone Charging
Discussion in 'Model X' started by bugZPDX, Dec 28, 2016.
Tags:
  1. bugZPDX
    bugZPDX Member
    Oregon
    Thought I'd share this fairly simple and inexpensive modification we made so we can wirelessly charge our cell phones.
    • Like x 11
    • Informative x 6
  2. flar
    flar Member
    Bravo! Thank you for this, I will need that solution as well.
  3. CurrentRide
    CurrentRide Member
    Charlotte, NC
    Would you be willing to post an instructable... or even start making them yourself for sale? Part of the attraction is how seamless the final product matches the original design. I had the same idea, and even bought a qi charger coil, but was afraid to take the lid apart. I think that Tesla only sells the lid as a part of the large center console, so if I mess up, it could be costly.
  4. balefire
    balefire Member
    Chicago, IL
    That is cool. Would love instructions too
  5. Dj B
    Dj B Member
    Nevada
    Rad video! Thank you for sharing!!
  6. bugZPDX
    bugZPDX Member
    Oregon
    I wish we had thought about taking pictures as we disassembled the entire console. We went back and disassembled the most confusing part and took pictures. Here are the basic steps:
    Qi Wireless charger - Amazon.com: Wireless Charger,Itian Qi Wireless Charging Single Coil DIY PCBA for Samsung Galaxy S7 S7 Edge S6 S6 Edge Note5 S6 Edge Plus: Cell Phones & Accessories
    1. Pull out rear console vent assembly. This literally just pulls out.
    2. Disconnect the USB connectors and extend the cup holders.
    3. Pull off the back panel of the console by hand.
    4. Move driver and passenger seats all the way back and recline both as far as they will go.
    5. Remove both side panels from the center console carefully with just fingers. There were about a dozen or so clips on each side.
    6. The pivoting cover will have two screws, one on each side, securing it to the console that need to be removed. Pay attention to how the soft close mechanism is attached.
    7. Two additional screws hold the plates together and also need to be removed then the two pieces of the pivoting cover will slide apart.
    8. Some of the plastic ridges on the back will need to be trimmed away to make room for the charger.
    9. Drill a small hole for the LED and sandwich the wireless charger between the two plastic plates.
    10. Test placement of the charging pad before permanently securing it between the plates and installing it back in the car.
    Hope this helps!
    • Informative x 6
    • Helpful x 2
  7. travwill
    travwill Active Member
    Chicago, IL
    Nice, great ingenuity.
    1. Question - did your phone connection kit, include the two guiding rails that a phone slips into to align it with charging port (if you were using it)? Our has the lightening iphone charger installed, but no guides so kinda have to eyeball it over the port and keep trying some.
    2. Hope - I'm hoping the iPhone 8 (10th anniversary one) has wireless charing, and hopefully it is the WattUp type solution that doesn't require a pad even, just a transmitter in the car. Let's hope for that :)
  8. bugZPDX
    bugZPDX Member
    Oregon
    Yes ours came with two sets of guide rails for different size phones. WattUp charging sounds awesome! I wonder how much power it can deliver to a device. Something to keep an eye on for sure.
  9. CurrentRide
    CurrentRide Member
    Charlotte, NC
    I really appreciate the instructions, but ended up running past my comfort zone. I started the disassembly as you outlined, but after removing the back panel, and while starting to remove the side panels, I chickened out.
    It takes a good amount of force to take off the side panels, and I kept imagining that I would permanently damage the console. As it is, I did end up cracking a small plastic bridge (no real harm) on the back panel, and I think that there may be a small side panel gap that was not present previously (although I might be imagining that, too). Chalk it up to paranoia, but I sweat small imperfections in this $135k car. Maybe I will try again after building my courage back up.
    I had bought this slightly larger triple coil, which might not fit in your design anyway:
    Amazon.com: Wireless Charger,Itian Qi Wireless Charging 3 Coils DIY PCBA for Samsung Galaxy S7 S7 Edge S6 S6 Edge Note5 S6 Edge Plus LG G3 G2 Google Nexus 4 5 6 7 Nokia Lumia 920: Cell Phones & Accessories
  10. bugZPDX
    bugZPDX Member
    Oregon
    @CurrentRide yeah I've never put my hands on the triple coil so you may be correct that it's too large. Removal of the side panels does take a good amount of force for sure and I completely understand not wanting to break anything. I'm not sure if it makes a difference but we started panel removal at the front of the car and worked our way back. We also saw a video of someone who removed their center console (to a much greater degree than we needed to) and they used some plastic pry tools they purchased at Harbor Freight.
  11. jnt76
    jnt76 Member
    Westchester NY
    I'm a chicken also when it comes to dismantling a 100K car. I got this free standing charger from Amazon with a circular base that fits perfectly inside one of the round cup holders. I ran the USB under the rubberized mat and into the bottom console. The charger has a non-slip ledge that prevents the phone from moving around. Does the job and I can close the top to hide my phone if needed.
  12. CurrentRide
    CurrentRide Member
    Charlotte, NC
    So... I did it!
    It was not easy for me, and I had a couple of hiccups along the way, but the final solution works well -- an identical design to that of the OP. I had hoped that the wireless charging would work through my phone case, but unfortunately it does not. It did work reliably in the case when I tested it inside, probably because the plug in charger was of higher amperage than the USB port in the car. Oh well, so the case is gone now and the S7 Edge looks sexier naked... as long as I don't drop it!
    20170107_150626.jpg 20170105_115236.jpg 20170114_093923.jpg 20170114_093244.jpg
    • Like x 4
  13. djgabriel2004
    djgabriel2004 Member
    Boca raton, FL
    Good job!! Didn't you take the console out?
    How was attached the plastic where you installed the Qi? Just clips ?
  14. CurrentRide
    CurrentRide Member
    Charlotte, NC
    I followed the instructions posted earlier in the thread. You have to remove the side panels of the console to remove the pivoting cover (by removing 2 screws at the hinge). Once the cover is out, it is easy to separate the two plates (held with 2 screws). It took a lot of time to shave down the plastic and rubber between the two plates in order to fit the Qi charger, which I just taped into place.
  15. djgabriel2004
    Boca raton, FL
    Perfect, I'll do it!!
    Thanks for your answer
  16. K-MTG
    K-MTG Sunshade Captain of TMC
    Irvine, CA
    Wireless Charging??? Not on my iPhone :)
    • Funny x 2
  17. bugZPDX
    bugZPDX Member
    Oregon
    Hey great job! And thanks a ton for the pictures!
  18. CurrentRide
    CurrentRide Member
    Charlotte, NC
    Hey, you deserve all of the credit for the original design, and the guts to make it happen!
  19. K-MTG
    Irvine, CA
    OP better file a patent
  20. CuriousG
    CuriousG Active Member
    Elk Grove, CA
    Is that Karina's tray? I would have thought it was a better fit. The gap on the left side is very noticeable from the picture. Of course you'll be sitting way above it so it wouldn't be noticeable then.
