Hey everyone I have a question regarding tires for my Vossen rims with 5mm spacers.
Background:
Currently I have Vossen VFS2 22x9 (5x120 +30) Front and 22x10.5 (5x120 +38) Rear.
For about a year I have had Nexen N5000 Plus tires, which I have been happy with, but the problem is the fronts are 245/30/22. These front tires are under the factory load rating and I found out can be dangerous to drive on. The person I bought the rims from said most people uses this tire size, since 255/30/22 rub when full tilt reversing. Well my 245/30/22 rub at full tilt reversing, so I don't know why I was recommended this. The rear tires are in spec and don't rub at all, even lowered on the lowest setting with UP Brackets.
Suspension Mods:
Lowered on UP Brackets FYI. Not sure if that matters
Spacers:
Here are the spacers I am looking to buy, unless someone knows of some better ones.
5MM TESLA MODEL S (2012-2019) WHEEL SPACERS 5X120 CB 64.1. | eBay
Questions:
Thank you in advance for your help!! Here are what the rims currently look like on my P85D. *Not the best pics*
Background:
Suspension Mods:
Spacers:
Questions:
- I want to change my tires to the Continental DWS06 tires 255/30/22 in the fronts and 295/30/22 in the rears. Has anyone ran these tires on this type of set up?
- Continental DWS06 tires are my only real choice, as I want all-season. Has anyone used these tires before? Experiences?
- If I get 5mm spacers. Will this help with the rubbing or make it go away when reversing at full tilt?
- Has anyone done this before with the same set up? I really think it will work, but I wanted to feel it out with you all first.
- No rubbing with 255/30/22 in the front
- Making the front rims more flush, without rubbing.
