So I had my new Gen3 Tesla Charger installed today and everything seemed to go well. My electrician ran 40' of EMT conduit from my breaker panel out the wall to my carport where the charger is mounted next to where the MY parks. He installed a SquareD HOM 60A two pole breaker in the box. He then pulled two #6 THHN wires and one #10 wire, all copper through the conduit. The #6 wires are on L1 and L2 while the #10 is the ground.
Everything powered up and the MY charges happily at 48A / 11V. However, after ten minutes or so of charging the conduit just past the breaker box started buzzing. Or rather the wires in the conduit were buzzing I'd guess? The electrician says that's normal and won't hurt anything. The breaker isn't getting hot, just a bit warmer than ambient, and everything does seem to work fine.
I'm worried about that #10 ground wire though. He said the ground doesn't need to be #6 and that #10 is fine. Is he correct? Is that causing the buzzing? I'm not an electrician so any advice would be welcome.
Thanks.
Thanks.
