Question about steering wheel controls
Discussion in 'Model S: Interior & Exterior' started by Panacea, Oct 30, 2013.
  1. Panacea
    Panacea TSLA Shareholder/Believer
    NJ
    Do the controls for voice command, fast forward, rewind etc on your steering wheel light up at night? Mine have never, yet last night I could have sworn they did. Maybe I need more sleep.
  2. efusco
    efusco Moderator - Model S & X forums
    Nixa, Missouri, United States
    No, unfortunately. Likewise there's no tactile feedback to help identify. In particular I'd like some bumps on the window controls so I can tell front from back, about 1/3rd of the time I lower the back when I intended the front.
  3. DIL
    DIL Member
    Danville, CA
  4. Shumdit
    Shumdit Member
    SC
    Mine are backlit
  5. Ajrdu
    Ajrdu Member
    Raleigh, NC
    Mine are lit as well.
  6. efusco
    I stand corrected...guess I just never noticed.
  7. Musterion
    Musterion 18h 03m 37s −24° 23′ 12″
    M8
    There seems to be buggy behavior with the backlighting (was also mentioned in another thread). On mine it sometimes comes on very bright, and other times very dim, independent of brightness settings for screen.
  8. Shumdit
    Shumdit Member
    SC
    Is it bright when you have 240 miles of range and dim when you have 20 miles of range? :tongue:
  9. jerry33
    Texas
    It's supposed to sync with the display, but sometimes it's not. However, any adjustment of the display brightness puts them back in sync (4.5, don't know if this is fixed in 5.6).
  10. Btrflyl8e
    Btrflyl8e Supporting Member
    Seminole, Florida, United States
    Wait, you all have buttons on your steering wheels?
    Jk, mine are backlit.
  11. Geoff
    Geoff Member
    Seattle, WA
    Mine are backlit as well.
  12. swegman
    swegman Active Member
    Interesting, mine are not. Never have been. FW 5.6 was downloaded today, so will have to check if it makes a difference.
  13. markb1
    markb1 Active Member
    San Diego, CA
    Note that the backlight only comes on when the touch screen goes into night mode. Mine really looked printed on while the backlight was off.
  14. johnmodels
    johnmodels Member
    SoCal
    Has anyone noticed that the "up" button on the left side of the wheel getting "worn" and not feeling as well as the other buttons. I use that butting a ton when using slacker radio. It is more recessed than the others. I'm thinking to have it looked into next visit to SC.
    john
  15. Shumdit
    Shumdit Member
    SC
    Maybe you need to be less picky about the songs you listen to:biggrin: JK!
  16. dgmanny
    dgmanny Member
    Metrowest Boston
    I have noticed the same thing.
