Just to add to the data here, I did my first and only 100% charge a few weeks ago and using Visible Tesla captured similar results to those reported by Andyw2100. In my case, this was 6 weeks after delivery with about 1500 miles on the car. I was charging at 40 Amps with voltage steady at 242 Volts (HPWC).
Once the car reported 100%, it continued to charge for an additional 30 minutes. During this time the current tapered down to 5 Amps. The taper was not linear, with current staying at 40 amps for about 5 minutes, dropping to 20 Amps over the next 10 minutes and continuing to decrease more gradually for the remainder of the time. About an hour after the charging finished the rated range increased from 273.1 miles (at end of charging) to 275.5 miles. This is for an 85D and as best I can recall, I had range mode enabled prior to starting the charge. I was not monitoring the displays in the car or in the Tesla App as I was in bed, asleep.
I did not experience any strange screen behavior. Both the 17" and instrument cluster screens were normal when I left on my trip, which was about 4 hours after charging completed (3 hours after the last range increase).
If the 1 hour lag between the end of charging and the range update is purely calculation of the data to update the range, that would be an enormous amount of computation. This suggests that there is more to the recalibration than just number crunching. The taper during the last 30 minutes of charging appears consistent with some sort of cell rebalancing.
