Snow Drift
[Off-Road Assist] Activated
MS and MX owners manual says ONLY on rear tires. There is an issue with clearance of the suspension bits.What do they say for AWD cars?
Subaru says (don’t use them) or front only. So it’s never all 4.
I may be wrong, but isn’t the reason FWD is desirable in slippery conditions is that the majority of the weight in most ICE vehicles tend to be over the front wheels? If so, since the Model 3’s weight ratio is 48:52 F:R, it should be at least effective in the snow as a typical FWD ICE vehicle.
Case closed, it handles very very well. watch this:
Agreed. The guy drives on pretty clear roads, a lightly covered parking lot and doesn’t seem to know how to do donuts.I wouldn’t say case closed since you haven’t seen anything in this video of how it does in hilly terrain in winter conditions.
Says the guy in Florida. Up here I'd say there's probably at least 30 days during the winter where we drive on roads covered with snow/slush/ice where anyone south of the Mason-Dixon would just stay in bed because the city is shut down. That said, you're right the Model 3 appears to handle these conditions pretty well on all seasons. I already ordered additional wheels from T Sportline for snow tires so I suspect that I'll be fine.The point is, I am very happy with content they showed. Most of the time, you wouldn't be riding if road is not clear and that's the type of environment they showed. In this environment, the car handled itself very well. If there is more snow, I'd rather stay home and not drive.
Your right, and that was the reason to move to Florida . I did spend about 10 years driving in upstate new York before Florida so was thinking about the slush and mostly salted / sanded roads when made the comment. Very few well traveled roads have packed snow without sand or salt and that would be an issue for most front wheel drive cars which I've been driving at that time. Also, planning to take road trips to mountains using fsd (that's right, I'll keep dreaming ) in m3 and again, most time mountain roads are cleaned regularly.Says the guy in Florida. Up here I'd say there's probably at least 30 days during the winter where we drive on roads covered with snow/slush/ice where anyone south of the Mason-Dixon would just stay in bed because the city is shut down. That said, you're right the Model 3 appears to handle these conditions pretty well on all seasons. I already ordered additional wheels from T Sportline for snow tires so I suspect that I'll be fine.
All season tires are a pox. This is why I will have a second set of wheels with proper winter tires for going to Tahoe… it's not that big of a deal to swap the wheels around if it prevents things like this.
There are certainly parts of the country where all seasons are sufficient. I've even got by with them here for many years but winter tires definitely perform better in the snow. As to the added cost, I really only consider the wheels to be extra. The tires are a wash. I just spread the annual tread wear over two sets of tires. Although you do have a higher up front cost for two sets.
heck I often see dry rot before the tread is gone on a single set if I get one of the types that has a 70,000 to 90,000 mile rating.
Are you joking?Tesla specifically says that they should only go on the rears to avoid damage from the chains.
Very good review which I highly recommend, but be prepared for a huge excessive amount of loud rock and disco musicFrom Teslarati:
Best look yet at Tesla Model 3 handling snowy conditions on standard tires Best look yet at Tesla Model 3 handling snowy conditions on standard tires
I'm mortified there are tires with hard enough compounds to last that long. I can't imagine the handling and braking tradeoffs. My motorcycle front tire lasts around 3,000 miles and the rear lasts around 6,000. My cars I usually get 25k or so… I've never had to replace winter tires though, because I only swap them on for weekends when I'm going to Tahoe and I change cars frequently enough so that the winter tires have never needed replacement.
Long lasting, or high traction, you only get to pick one… and I always pick traction.
While tesla uses the W rated tire on the S when using the Primacy MXM4 I've never done 168 mph sustained (heck I've never done over 110 short term) and I see no need for that sort of speed rating. Tirerack shows both V and W rated Primacy MXM4 tires in the size needed for the Model 3.
The traction isn't significantly different between the speed ratings in the kind of driving an average driver does and so I'd end up getting the V rated version to save money.
If you by an All season that does nearly as well as a summer tire (like the Michelin Primacy) and a different all season that does nearly as well as a winter tire (like the Nokian WRG3) that'd make for a proper summer/winter rotation here (and would work in other parts of the country).
Speed rating and size matter, I won't run the larger wheel sizes no need looking at the 19" or 20" tires for the Model 3 as far as I'm concerned.
Continental PureContact with Ecoplus is rated for 70,000 miles in the size needed for the Model 3 (235/45R18) and is V rated (149 mph)
Energy Saver A/S is rated for 65,000 Miles (S- T- & H-Speed Rated) or 55,000 if V speed rated on the Model 3 and (235/45R18) then in that case it is V rated (149 mph).
Primacy MXM4 (an OEM Tesla tire used on the Model S) is rated 55,000 Miles (H- & V-Speed Rated) 45,000 Miles (W-, Y-, & Z-Speed Rated). In (235/45R18) they have both V (149 mph) and W (168 mph) ratings.
So yeah those are the tires I'd be looking at for replacements when my Model 3 needs a set down the road (or at least whatever the equivalent to those is by then).
At 10,000 miles a year a tire rated for 25,000 miles would last me 2 or 3 years so no issue with dry rot. But the tires I get last me 5+ years and eventually I replace them due to age of the rubber just as much as I do for keeping the tread deep.
So age of rubber and tread depth remaining are important on top of the tire you buy. Just because a tire is rated for 90,000 miles doesn't mean it's traction hasn't gone to crap after 50,000 miles and I don't pretend that any tire with >50,000 miles on it has great traction no matter the age or brand or size or any rating I could name.
I just checked and the Nokian WRG3 does not come in the 235/45R18 or 235/40/19 size for a Model 3. So I guess that tire is out of the question.
FWIW compared to the tires above it is rated for 55,000 miles.
That mortifies me, too. I sometimes rent a car with high mileage tires, and I always almost die in those cars. I quickly return them and get something with big beefy tires that are meant for traction. Cars with high mileage tires are death traps.I'm mortified there are tires with hard enough compounds to last that long. I can't imagine the handling and braking tradeoffs. My motorcycle front tire lasts around 3,000 miles and the rear lasts around 6,000. My cars I usually get 25k or so… I've never had to replace winter tires though, because I only swap them on for weekends when I'm going to Tahoe and I change cars frequently enough so that the winter tires have never needed replacement.
Fortunately, my winter tire of choice, the Nokian Hakka R2, is available in the right size
Interestingly enough Nokian does not have a tread wear mileage warranty on the Hakkapeliitta R2.
