Question: Model Y Accident Question
Hello, I recently took delivery of a Model Y Long Range with the 7 seat option. I drive 80 miles a day and overall love the car. Having two little ones now overall safety of a vehicle comes into play. We had a 17 Mercedes GLE as the family car but the Model Y replaced it. Both our kids are in car seats and the 3rd will come into play a handful of times a year (all ready used it once). So that is great to have. A friend of a friend recently crashed their model 3 into a ditch recently and supposedly the battery of the car died. Supposedly there was no way to open the Model 3 from the outside because the battery was dead. So now my wife is worried about a similar situation with the Model Y.
So my question is does anyone know if there is a way/easy way to get into the Model Y from the outside if we did get into an accident and we could not open the doors from the inside? I know about the manual releases from the inside out but the problem/question is getting people out of the back in case of an emergency.
Thank you!
jcanoe
5,510
6,024
Maryland
same as any car. side/rear glass is designed to break into tiny pieces that won't slice you. Small sharp object.
That is no longer true for the front door windows in the Tesla Model Y. The front windows now use laminated glass, same as the windshield. To break through laminated glass requires a different tool, i.e. a small fireman's axe to smash through the glass layer and the middle plastic layer and pull out the window through the opening.
Kuzco
Emperor
Feb 2, 2021
173
399
Also note that getting OUT of the car from the inside will be an issue if the battery is disabled. The front two doors have a mechanical release but the rears do not to my knowledge.
The rear doors have a manual release, although it is a bit tough to access. It’s under the rubber lining at the bottom of the door pocket.
See this video for more info:
SabrToothSqrl
3,972
3,489
PA
I did not know that, is it in the manual or any vids? thanks
jcanoe
5,510
6,024
Maryland
Tesla added the laminated glass to the front door windows ~Sept 2020. If you search for Tesla Model Y laminated windows you should find some articles. (If you look closely at the driver's window of the Model Y, if the Model Y has the laminated glass, you can clearly see three layers Glass|Plastic|Glass.)
