Question of curiosity: How many electric motors does Tesla have in production now?
Discussion in 'Model S: Driving Dynamics' started by SeminoleFSU, Oct 12, 2014.
  1. SeminoleFSU
    SeminoleFSU Voluntaryist
    Atlanta, GA
    #1 SeminoleFSU, Oct 12, 2014
    Ex.
    1. Roadster engine
    2. Roadster sport engine?
    3. Non-perf Model S engine
    4. Performance Model S engine
    5. Rear engine for S85D
    6. Front engine for S85D
    7. Rear engine for P85D
    8. Front engine for P85D
    Surely some of these are the same motor just configured differently for AWD or performance variants??
    So what's the total number? Which engines are shared across different models?
    which motors have been discontinued but are still being supported by service? Obviously the Roadster variants
  2. Raffy.Roma
    Raffy.Roma Active Member
    Rome (Italy)
    Imo 3 (2), 4, 7, 8 that is to say 5 motors.
  3. SeminoleFSU
    Atlanta, GA
    #3 SeminoleFSU, Oct 12, 2014
    Single:
    Dual:
    I remember reading somewhere that the single drive versions of the MS use the same motor across the P and S variants.... There's just an upgraded inverter? that gives more power in the performance model, but the motors are the same? Is that true? I'm 90+% sure the motor is the same in the single drive 60kWh vs 80kWh models... Only difference is the battery.
    Then we have the dual drive configurations...
    Looks like they're saying the 60D and 80D share the same 188hp motor for front and rear.. This looks to be a brand new motor not offered before (I think?)
    Then we have the P85D. It says 470hp rear and 221 hp front. I'm assuming this means the same 470hp rear motor as the single drive P85, but is the 221hp front motor is possibly a 2nd NEW motor configuration, or is it just the same 188HP motor used in the non-perf 60 and 85 just getting more juice from a beefier inverter?
    So...
    If the single motor S60, S80, P85 all share the same motor that's 1.
    Then if the S60D, S80D, and P85D fronts are all the same that's 1.
    Then you have the roadster and roadste sport, which I'm not sure if they're the same or different motors...
    On the low end it seems like you'd have 2 different MS motors and possibly 2 roadster motors bringing the total to 4... or if there are differences between the P and S RWD motors, and P and S FWD motors, that # could balloon to 4 different MS motors and 2 different roadster motors for a total of 6 distinctly different motors...
  4. Chris TX
    Chris TX Active Member
    Dallas, TX
    Only two different motors: One for the front, and one for the rear.
    The only difference is the inverter/converters for the P to give more power, and software limitations on the 60 variants (both D and non-D)
  5. SeminoleFSU
    Atlanta, GA
    #5 SeminoleFSU, Oct 12, 2014
    That would certainly make more sense from a modularity perspective and keeping things simple (stupid) :) for the production line... But how sure are we?
    - - - Updated - - -
    What do you mean by 3 (2)? That the non-performance single drive comes in two motor types? a 60 and an 80? Seems like the HP #'s would be different then?
    - - - Updated - - -
    MODS: If this is being discussed in another thread, my apologies. Feel free to point us there or merge as needed.
  6. Raffy.Roma
    Rome (Italy)
    #6 Raffy.Roma, Oct 12, 2014
    3 stands for Non-perf Model S motor and (2) stands for the motors of the 60 KWh and 85 KWh. I don't agree with Chris because IMO the inverter belongs to the motor.
  7. SeminoleFSU
    Atlanta, GA
    I think Chris might be correct... just 2 different engines overall for MS... and soon MX
  8. gavine
    gavine Petrol Head turned EV Enthusiast
    Philadelphia, PA
    Why is the lighter 60 slower than the heavier 85 if they have the same horsepower? The original 60 has less HP. I'm thinking that's a typo. Either the 0-60 or the HP is wrong.
  9. amzng_ev
    amzng_ev Member
    Los Angeles
    At the keynote, Elon definitely said they would put a larger motor in the front of the P85D. I do not know if he was just referring to power, but he made it seem like the motor was unique to the car.
  10. SeminoleFSU
    Atlanta, GA
    Should be a typo I guess? I think it's a question of sustained peak output from the pack..
