This is a rather technical engineering question
Any comments explaining the opposite design are welcome
I had solaredge earlier and at around 99 percent efficiency , its is completely passively cooled
I think it has no wholes/vents for air to flow freely outside, its a completely enclosed case
In other words, at the 1% inefficiency , heat generated is very very less. ( If we assume all inefficiency is converted into heat)
Now the Tesla inverter is completely opposite , could not be further apart in terms of heat dissipation design
With water cooling, its like a Model S plaid version for heat control and dissipation
In addition to water cooling, it also has fan cooling, and kind of vents on the side of for fan air to bow out hot air
So why at 97% efficiency we do need such a tremendous double system for cooling ?
Questing is 1% vs 3% heat generation is such a big difference??
if you calculate 1% heat generated - solar edge perhaps needs more cooling and open vents...
Picks your sides in design and thermodynamic
Thx
Thx
