Hi,
I get quite high energy consumption while driving in cold weather. Example: 41 mi, 40 F, 65 mph mostly highway => 340 Wh/mi. Sounds not that high, but: That is with cabin temp set to 66 F and seat heater set to 1, so no too comfortable... The car is pre-heated for about 10 min which is enough to get the interieur warm but not the battery of course.
In the energy app I see a broad peak at the beginning of the drive which I interpret as the energy consumption of the battery heater. This peak offsets my average...
I never tried to set range mode to "on" because I don't know if that is bad for the battery life. If the battery isn't heated actively, it longer stays in a condition where it has limited performance (regen and max power). But that wouldn't be much of a concern to me. And I wouldn't mind the reduced power of the cabin heater, too.
So the question is: Does "range mode off" help to reduce battery "wear" in cold weather, or is it just for the convenience of having full regen and full power more quickly? Or put it the other way round: Can I use "range mode on" without any technical concerns?
Thanks,
Bernd
Thanks,
Bernd
