Questions about charging at 120v block heater outlets
Discussion in 'Model S: Battery & Charging' started by Kenypowa, Jul 22, 2015.
  1. Kenypowa
    Kenypowa Member
    Calgary, AB
    If a 120v block heater outlet is 50% duty cycled,
    1) can the car battery still be charged at half rate?
    2) will it damage the battery in the long run?
    Any response is greatly appreciated. Thanks :smile:
  2. Rocky_H
    Rocky_H Well-Known Member
    Boise, ID
    I'm not sure what you mean by "50% duty cycled". Do you mean there is actually a timed switch inline with the circuit that makes the circuit live and disconnected for alternating periods of time?
    1. If the power cuts off like that, I think it will automatically resume charging when the power comes back on, but I'm not totally sure.
    2. It won't mess with the battery, but if charging doesn't resume, the UMC and/or charging system may think the circuit is unreliable and be sitting there waiting for you to tell it that it is OK to start charging again.
    Anyone confirm how that behaves from a power interruption?
  3. InternetDude
    InternetDude Member
    Yes
    Stay at a different hotel...? I've seen some hotels listed on plugshare like that, 30 mins on, 30 mins off. All I think when I see that is thanks for the warning, I'm going to book somewhere else.
  4. Cosmacelf
    Cosmacelf Well-Known Member
    San Diego
    If power cuts out, and then resumes after a period of time, the car will just resume charging.
  5. mknox
    mknox Well-Known Member
    Toronto, ON
    One thing to be aware of with block heater outlets is that the voltage is not always "reliable". When all you're doing is powering a resistive heater, concern for a nice even 120 volts is not a high priority. I believe there are even some block heating systems that manage loads across numerous vehicles in a parking lot by throttling the voltage. Not 100% sure on that last point, but I recall seeing something about this for shopping centers and other large parking lots some time ago.
  6. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    It would make me nervous. I can't imagine that it is very clean power, even considering the MS can and will analyse that and default toward safety. At the very least, those outlets will charge you at a rate of approx 1-1.5 mi/hr, given the on/off issue. Not a lot of juice.
  7. Duma
    Duma Member
    I wouldn't worry too much about other cars plugged into the circuit. The only time other cars will plug in for the block heater will be in winter. In winter there is no point to trying to charge a Model S on 120 V because all the energy gets diverted to heating the battery rather than charging. In other seasons, might be helpful to have a trickle charge to add a few miles overnight.
    (Whether it is worth plugging in to keep the battery somewhat warm on a very cold night is a different question.)
  8. DMC-Orangeville
    DMC-Orangeville 85D and John Deere 5100E
    NW of the 6ix Canada
    ...and it could be an "intelligent" block heater plug as well. Many of these are being installed - they won't function above 40 F, 4C. See: https://www.iplc.com/files/IPLC_Fleet.pdf . Great for block heaters, not so great for charging.
  9. Kenypowa
    Kenypowa Member
    Calgary, AB
    Thanks for all the responses. The block heaters near work and home are both older style and they do have power all the time (tested with a multimeter).
  10. efusco
    efusco Moderator - Model S & X forums
    Nixa, Missouri, United States
    I'd argue that that is the very best time to keep the S plugged in. I use a 120v at work in the winter all the time for that very reason. I still get at least 2-3 miles/hr of range AND the battery is much warmer, I'm able to operate at nearly full power instead of being power and regen limited as it would be if I let it cold soak for the entire 9 hours of my shift. I plug in in the warm weather just because I can, but the benefit is minimal other than a few cents worth of free juice.
