Quick ? on Auto Lane Change
Discussion in 'Model 3: Driving Dynamics' started by SanteeMike, Jan 8, 2020.
  1. SanteeMike
    SanteeMike Member
    El Cajon, Ca
    I have an M3 with all the bells and whistles. I'm trying to turn on the auto lane change - the car tells me it wants to change lanes but first, it always asks to continue and I have to shake the wheel to acknowledge the lane change.
    Is that the way it's supposed to work or am I missing a checkmark or radio button in the control screens?
  2. JulienW
    JulienW Active Member
    Atlanta
    You are using Navigate on Autopilot without confirmation. Yes that is the way it works. You must confirm your hands are on the wheel before it will change lanes.
  3. SanteeMike
    SanteeMike Member
    El Cajon, Ca
    Thank you. I thought that was the way it should work but I keep seeing Youtube vids where it doesn't appear the driver is confirming the lane change. I just wanted to make sure. I guess I still have to stay awake :)
  4. Thp3
    Thp3 Member
    Michigan
    #4 Thp3, Jan 8, 2020
    When you first get a Tesla, you should reread the manual. There is a large learning curve and the manual helps when you understand the context.
    @JulienW schooled me. I usually require turn signal confirmation just to remain focused. Thanks.
  5. ewoodrick
    ewoodrick Well-Known Member
    Buford, GA
    There are two types of "confirmation". although Tesla only says that one is confirmation.
    What you are hitting is considered a passive confirmation of change because your hands should be on the wheel with torque anyway.
    If you have your hands on the wheel providing torque, the change will just happen. If there is not torque (i.e. car doesn't know you are active) it waits for torque to change lanes.
    You don't have to shake the wheel, just slight torque in a single direction is all you need. It's much more comfortable to the passengers than the car wiggling.
  6. PianoAl
    PianoAl Member
    Far Northern California
    Just read a post in which someone said clicking or adjusting the scroll wheels can also act as confirmation. I haven't tested that yet, but I like that idea more than turning the wheel slightly.
  7. JulienW
    Atlanta
    #7 JulienW, Jan 9, 2020
    Not for NoA lane change. Adjusting scroll wheels works as a regular confirmation. Lane change requires a torque to activate unless you have confirmation off. If off you must use the turn signal but this acts as a confirmation.
    EDIT: Also I'll add as a newbie it is harder to torque the wheel the right amount. When I fist got mine I would use the scroll wheels and when I tried to torque it didn't seem to work and I would shake it harder and harder until AP cut off. After a few more weeks you will just naturally torque it the right amount every time without any thought.
  8. SanteeMike
    SanteeMike Member
    El Cajon, Ca
    :) - When I said "Shake the wheel" I didn't mean I threw the car back and forth in the lane. Yeah about a half-inch is all that's needed and the passenger doesn't even know it happened.
    I also DID RTFM but was confused because the setting said "lane change - no confirmation" and I was having to confirm every move.
    Thanks guys, at least I know now.
  9. Spacecadetwzrd
    Here
    There is a sweet spot on the wheel where you can rest your hand. It basically eliminates all confirmations/nags.
    for me its
    -left arm elbow on left thigh
    -left hand 4 fingers palm down on top of the wheel inside the hoop right where the scroll wheel is.
  10. SanteeMike
    SanteeMike Member
    El Cajon, Ca
    I hold the same way except I pinch on the bottom of the wheel. Long drives from San Diego to Vegas gets boring so I'm usually reading my Kindle j/k.
  11. PianoAl
    PianoAl Member
    Nice!
