QuickJack to produce Tesla-specific model
Discussion in 'Model S: Driving Dynamics' started by Musterion, Aug 10, 2017.
  1. Musterion
    Musterion 18h 03m 37s −24° 23′ 12″
    M8
    QuickJack (QuickJack - Car Lift for your Home Garage or Shop) has been mentioned in a few jacking threads here but so far has not made a model with sufficient jack point spread to accommodate the Model S. I've been waiting patiently as they upgrade their collection, but their longest EXT model is still 4-5" short (although it has sufficient weight rating). But today I got an email from a VP there with drawings for a Tesla-specific model with sufficient spread, and he says it is 90 days out and will be announced soon. If true I hope to get a set soon and will report back here. No affiliation -- I have been trying to put together a compact and low-cost 4-wheel lift for some time now and this design fits my space constraints and doesn't require permanent mounting.
    • Informative x 2
  2. Drewflux
    Drewflux Member
    Australia
    Very interesting. Just out of curiosity, do you happen to know the distance between the jack points. Im supprised the long version comes up short. I have had some large pickups on an older quickjack.
  3. The Duke
    The Duke Member
    How much does the lift travel when you lift? I only have 6" to spare in front of the car and it looks like the QuickJack uses more than that.
    Answering my own question, they call it radial lift and the car moves about 13 inches.
  4. SomeJoe7777
    SomeJoe7777 Marginally-Known Member
    Houston, TX
    I'd definitely be interested in one if they have a Tesla-specific model.
  5. HankLloydRight
    HankLloydRight No Roads
    Connecticut
    Very interested!
  6. William_B
    William_B New Member
    Ohio
    Thanks for the info Musterion, I am very interested in this jack too.
  7. Chaserr
    Chaserr Active Member
    Logan
    Wow, these are cheap and I have to have one. Thanks for the heads up!
  8. Saghost
    Saghost Well-Known Member
    Delaware
    I missed this thread the first time around. I'll be interested to see if their new solution works for the X as well - it could come in handy. :)
  9. Bebop
    Bebop Active Member
    Midwest
    That is a super cool product! Great design work.
  10. arcus
    arcus Active Member
    Denton, TX
  11. deonb
    deonb Supporting Member
    Redmond, WA
    What exactly is the point of lifting a Tesla 20” off the ground?
    What else are you going to do while it’s jacked except for changing a wheel?
  12. jelloslug
    jelloslug Active Member
    Greenville, SC
    you can use it for the annual maintenance. It's also really handy for detailing the car.
  13. Gwgan
    Gwgan Almost a wagon
    Maine
    Flood preparedness
  14. jaguar36
    jaguar36 Active Member
    NJ
    Lots of us like to work on cars and just because it doesn't have an ICE doesn't mean there isn't still a lot that needs to be done. From maintence on brakes and coolant, to replacing worn or failed parts on the drive, suspension, steering or A/C systems.
  15. deonb
    Redmond, WA
    How much of that is accessible without removing the battery?
  16. Chaserr
    Logan
    Great point! Lifting the car makes battery removal easier as well. Does this quickjack have any crossbeams that would get in the way of working on the battery? The pics I see make it look like 2 separate sides but I'm not finding any without a car on it to be 100% sure.
    To answer your question: removal of the battery really isn't necessary for brake work, or AC, or suspension, etc. But it would be nice to be able to do it.
  17. deonb
    Redmond, WA
    How do you work on the AC that would have jacking up make it easier? I know the AC is accessible through the frunk once you remove the liner, but is it from underneath as well (without removing the battery)?
  18. mongo
    mongo Well-Known Member
    Michigan
    Could you start with your vehicle further out of the garage (7+inches) so that once it is raised, it fits inside?
  19. Chaserr
    Logan
    If all you need to work on is AC, you're probably better off not getting a jack of any sort and just bringing your car in for service; this type of product is for people who like to work on their own cars in general. I personally never work on my own AC system, it's just not my wheelhouse regardless of car and on the Tesla it's never needed any sort of work, but I've done most of the rest. But if you're doing the annual on the battery's cooling system then lifting the car will absolutely help.
