Quirky Charging Error
Discussion in 'Roadster' started by Doug_G, Aug 22, 2013.
Tags:
  1. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Charged today at a friend's summer home. The only unusual thing about the location is the line voltage is pretty high; it started at 251V and went down to 244V under load. I charged for two hours the first time and everything was normal.
    When I returned later, when I plugged in it gave a message, which said approximately "Battery Voltage Low. May charge slowly at first. Recommend using MC240." It was charging at a whopping 7A.
    I cycled the slider on the UMC charge cable. The car charged normally.
    When I returned an hour later to drive the car, everything was charging normally. I went away for five minutes and as I returned I heard the "brap brap brap" of an error. This time it said, "Charging Problem - ID:920 Data 0x00080000". Cycled the plug again and it started working. Stopped it again and drove home. Seems to be charging normally at home.
  2. jaanton
    jaanton Roadster NA #1026
    Oakland, CA
    I got that once when my battery was very low. Only mine said use to use the MC120. So I switched to that and after several hours I went back to my UMC. Really could be a problem if that happened on a trip.
  3. Doug_G
    Ottawa, Canada
    Yeah, but I had 130 km range left...
