I'll keep an eye out for your experience and feedback. I pulled all my 910 pads today, front and rear, and they are all glazed over again. Fronts after 2 sessions yesterday, rears I have not checked since I put them on...they have 6 HPDE sessions on them. XT910s are definitely not sufficient for the track IMO.
Sanded the glazing off the pads, hit my stock rotors with an 80 grit flapper disc to get any old stock pad material off and reinstalled. Brake pedal feel is much firmer already. Still need to go bed the 910s into the stock rotors.
I also hit the RB rotors with the flapper disc, I think they were glazed as well. Those are cleaned up now and ready for whatever track pads I decide to go with.
My experience so far is that this is a sign of glazed pads. Fresh pads don't heat up enough to set off the message, but once they glaze over, you are harder on the pedal, which causes more heat, which causes more glazing, on and on. At this point there's enough heat in the system to set off the warning. Mine got so bad on my first session yesterday that track mode shut off and I started getting warnings for stability control disabled, AEB disabled, hold mode disabled, auto pilot disabled, etc. Once everything cooled down it was back to normal.
If you get a chance, pull the pads and look at them. Here's one of my glazed ones today next to one that I sanded down.
