Danger of using CAN reader that can also post messages...All good now....phew. It went nuts when TA started scanning for parameters.
Nice wheels!
Do you know what temperatures you're getting the rotors up to?
Just tried to let TrackAddict connect to the MX and the car went nuts....heards motor under the car spin up, contactors were clicking back and forth, got all kinds of error messages on the screen. Unplugged MX and powered car off....hoping all is normal when I power back on in a few minutes. Weird. Guess I won't be doing that again.
I think i read that someone is using adhesive for the Endless pads instead of the OEM shim? I'm running Unplugged pads at the moment so i'm not going to hold my breath on being able to find the OEM shim, but maybe...
Both @destructure00 and I are using "adhesive" to hold the pad in place. I am using the CRC Disk Brake Quiet, he is using liquid engine gasket I believe.
Ha that same thing happened to me! I was gridding at Buttonwillow and the car just suddenly went into Park and refused to budge. After being super confused for 5 minutes, i realized it may have been the MX OBD2 dongle causing problems so i yanked that out and everything worked after that.
Good information to know. Would Harry’s Laptimer cause the same issue?
How's the CRC working?
