  • The final cut of the 8th episode of the Tesla Motors Club Podcast, featuring Balazs Biro, of the prominent Hungarian EV channel Villanyautósok, is now available. You can watch it now on YouTube or listen to it on all major podcast networks.
Rain not beading on windshield
Wipers stuttered on my model 3 if not enough rain on it. the problem went away with new wipers.
RainX coating imho is crap because it leaves momentary streaks after wiping which is annoying in light rain.
Imho a quality sealant is better i.e. spray sealant or something like jetseal.
I would say that the quality of the beading is maybe 90% that of RainX but it lasts longer and no annoying streaking.
joebruin77
1,241
1,158
Encino, CA
I can think of 3 possible causes of your wiper chatter:
1) The glass, despite being cleaned, still has some contaminants bonded to it and needs to be polished to get the contaminants off.
2) Despite the blades being new, there is something on the rubber of the blades, such as a wax or sealant, that needs to be cleaned off.
3) The wiper blade arm is not holding the blade against the window with enough pressure and something in the arm mechanism needs to be adjusted. If you gently and lightly pull slightly on the wiper, does it snap back into place or does it feel a bit loose? If it is at all loose, it needs to be tightened or adjusted.
Hi, hgmichna,
Just curious, what do you disagree with? Not asking out of being defensive or anything like that. Just really curious to know. Please post a reply when you can.
Thanks,
joebruin77
Hi, hgmichna,
Thanks,
joebruin77
I think you got all three points the wrong way around. Or perhaps at least two of three. Wiper chatter happens with new, clean wipers on a clean windshield. Put some wax or almost anything else on the windshield or on the wiper and it ceases. Wiper chatter happens when the wiper pressure is high, not low.
joebruin77
1,241
1,158
Encino, CA
That's a good point to consider. I am guessing that wiper chatter could happen in either direction with either too much or too little pressure, as I have personally experienced wiper chatter due to the causes I originally referenced.
wax on windshields is a good way for showroom gloss but the only thing it will do is with wipers is grease them up nciely so you get massive streaking and smearing.
Reactions: valaeyron
