Rain sensing wipers - AP2 (is there a trick)?
Discussion in 'Model S' started by tstafford, Sep 13, 2018.
  1. tstafford
    tstafford Active Member
    Nashville, TN
    All,
    I have the setting turned on for auto-wipers but as far as I can tell they don't seem to work. At the lowest setting the wipers just run continuously with a delay/pause at the bottom. This happens rain or shine.
    Am I missing something? Rain sensing wipers worked fine on my P85D.
    Thanks,
    Tim
  2. ucmndd
    ucmndd Well-Known Member
    No real trick, they kinda suck. Your suckage sounds extreme though.
  3. Firewired
    Firewired Member
    San Antonio
    Something is not right. I had a P85D which had a separate Bosche rain sensor. They are now using one of the front facing cameras with AI. At least for me, when rain sensing finally rolled out it really sucked, but has steadily improved. The only thing I for some reason get a false wipe from is my LED garage lights. Otherwise they turn off when no rain. I would bring up with service. If you find anything out, please share.
  4. brendon1970
    brendon1970 Member
    Newcastle, New South Wales
    That does not sound like the way AP2 autowipers behave. They are certainly not perfect but I agree they are getting better.
    Normally people complain that they are too insensitive. Wont wipe until the windscreen is very wet, but I’ve been able to make them work well enough on low sensitivity with a recent build.
    They don’t work super well at night - seem to need a bit of external light to see the raindrops effectively.
    They are quirky - showing the car a dark wall, or a dark line of trees will often trigger phantom wiping as the NN interprets the dark as being a blocked/dirty windscreen.
    Running constantly - no I think something else is wrong.
  5. E-Ryc
    E-Ryc Member
    Prague, CZ (EU)
    Just for sure, do you have the ring in right position? (I worked as customer support for a while :) ) Or, does it wipe continuously in all positions? If so, I'd call service
    Ultimate solution - go to Freemont and kick Musk's a** to make him existing stuff working instead of "Atari games" features
  6. daktari
    daktari Member
    Norway
    You are probably aware that there is two switches, but you post is ambiguous on this. One software setting "enable auto wipers (beta)" AND the wiper stalk. If not the first is enabled, the wipers will act with a fixed interval in the first to settings on the wiper stalk.
  7. drklain
    drklain Active Member
    Scottsdale, AZ/Fairfax, VA/Brussels, BE
    My experience is that when I take the wipers from "off" to the lowest level of auto (first click after off), the wipers run fast and continuously for about 4-5 wipes (presumably as the camera and software determine what the rain level looks like), it then always slow down to some level of intermittent wiping (assuming I'm not in heavy rain where I would want them wiping continuously anyway). But those first wipes do seem to last a long time and make you think it's not working...
  8. tstafford
    Nashville, TN
    Thanks all. I'll give it another try tomorrow and see if any of these suggestions do the trick.
