Rain Sensor?
Discussion in 'Model 3: User Interface' started by ratsbew, Sep 3, 2018.
  1. ratsbew
    ratsbew Member
    Does anyone know if the Model 3 is using a traditional rain sensor for the auto wipers or if it is using the autopilot cameras? I believe that the circle visible on the camera housing is a rain sensor so one would think that it is using this.
    Does anyone know??
  2. wtwieder
    wtwieder Member
    Beachwood, Ohio
    It is the camera at the top of the windshield in front of the rear view mirror. It seems to respond more slowly to water buildup on the windshield then I would like. Actually, I wondered if treating the windshield with Rain-X everywhere but the camera area would help. In that way water wouldn't accumulate on the window as quickly as water droplets in front of the camera. The wipers would turn on just as before but when the window wasn't so so covered, you couldn't see. Has anyone tried doing this?
  3. ratsbew
    ratsbew Member
    I made the mistake of putting RainX ONLY on the cameras thinking that it would help autopilot, but not thinking that it would hurt auto wipers....maybe I should do it your way and only do the windscreen but not the cameras.
  4. Dana1
    Dana1 Supporting Member
    Houston
    Nope. My windshield is treated and I thought that was slowing down windshield wiper response time because the treatment beads up so fast.
  5. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
    I had read that the dot's a humidity and temperature sensor and that rain detection is done by the camera.
  6. Vitold
    Vitold Active Member
    NM
    Per Director of AP, AI is doing rain sensing.
    Worth watching if you have not seen it:
  7. chillaban
    chillaban Active Member
    Bay Area
    It’s definitely vision / AI based on the fisheye camera.
    The dot is just a lighting sensor for controlling screen brightness and auto headlights.
  8. aronth5
    aronth5 Long Time Follower
    Boston Suburb
    Just curious but why are you asking? Of all the shortcomings in the 3 getting the windshield wipers to work well is first on my list.
    My apologies to those who continue to have phone connection problems since my phone works pretty well now and has improved since I've had the car.
  9. broncobilly
    broncobilly Member
    Lakewood, CO
    #9 broncobilly, Sep 3, 2018
    On the 26th day, after almost 6000 miles of driving, the first significant rain occurred at night in Kansas. AUTO ceased to be effective. Light rain brought on fast; heavy rain ran the intermittent mode. Splashback brought the wipers to stop totally. I took it in only to be told that there were still programming issues. NOW THEY TELL ME!!!
    Obviously, I ended up using manual mode, but it was not helpful on the interstate when it is pitch black and the lines in the road cannot be seen. Having to work the screen to get the wipers to operate as needed, was, of course, not helpful. The lane change "shaker" did not work. After driving 6000 miles, I was exhausted and not in any mood to have to "learn" how to drive and control the wipers.
  10. wtwieder
    wtwieder Member
    Beachwood, Ohio
    I thought Rain-X was supposed to prevent water from beading up, so instead it sheets off. Therefore, if you apply it to every portion of the window except to the glass in front of the camera, the camera would see the buildup, before the rest of the window absolutely needs the wipers.
  11. SigNC
    SigNC Member
    NC
    no it makes it bead easier so it slides off
  12. SigNC
    SigNC Member
    NC
    Easy way to manually start wipers is to tap the button on the left stick for a single wipe. This in turn flips the monitor to the wiper page where you can easily turn them on.
    • Helpful x 3
  13. wtwieder
    wtwieder Member
    Beachwood, Ohio
    #13 wtwieder, Sep 5, 2018
    Look at this picture of both a treated and an untreated window. It clearly shows more beading on the untreated window. The treated window has less beading and gives greater visibility with the same rain. Hence, the name Rain-X refers to it repelling the rain so you don't need your wipers so soon. If it were to cause beading, as you suggest, it would be causing the rain to adhere. Again, treat the window which won't bead but don't treat the sensor camera area which will continue to bead up until it triggers the wipers.
  14. broncobilly
    broncobilly Member
    Lakewood, CO
    Splash back is still a problem.
  15. SigNC
    SigNC Member
    NC
    Incorrect, the water beads on the reduced surface tension of the treated window and slides off. The reason you see less on the left side is because the lowered surface tension allows the water to bead into a large enough drop that is slides off. On and untreated window the surface tension is much higher and the water does not slide off as readily. Ride in any car treated with rain x and this is immediately apparent when it rains.
  16. wtwieder
    wtwieder Member
    Beachwood, Ohio
    To me a bead is a tiny drop of water. If, as you say, with a treated window, a bunch of beads coalesce into larger drops or a sheet of water, you still don't see as many beads. Otherwise, why would you use this product?
  17. SigNC
    SigNC Member
    NC
    They do coalesce into larger drops which go off the windshield. In my experience the camera is better at seeing large beads of water than it is seeing a "sheet" or drizzle.
  18. wtwieder
    wtwieder Member
    Beachwood, Ohio
    It appears that Ratsbew had tried treating the camera area. So if larger droplets did, as a result form there, they rolled off too quickly. I am guessing that when the camera can't see clearly ahead because of a lot tiny droplets, the wipers are triggered. I just treated all of my window with Rainx but avoided the camera area. Now, I'll just have to wait for it to rain.
  19. bento
    bento Member
    Florida
    I find the rain sensor not very responsive to the rain conditions. Most of the time, I end up having to activate the wipers myself. I wish they had a sensor sensitivity setting.
  20. scott8659
    scott8659 Member
    Westerville, OH
    This. How hard is it to do a basic car function like wipers? Every other car company has managed to figure it out. Wake up Tesla. Early adopters and fans will tolerate this BS but the average consumer will not.
