Random Honk 3 times when charging
Discussion in 'Model S: Battery & Charging' started by scottkriz, Jan 12, 2015.
  1. scottkriz
    scottkriz New Member
    manhattan beach, ca
    It's happened twice now. When plugged into a 12A wall charger, after a few hours the horn honks 3 times. Is this a glitch with the mobile app is something wrong with my car? Also one time when I opened the sunroom from the touchscreen, the heat automatically turned up all the way and my seat heater went to level 3. Any help?
  2. Todd Burch
    Todd Burch Voltage makes me tingle.
    Smithfield, VA
    I can't help with the honking short of someone using the app to play a trick on you.
    As for the phantom touches on the touchscreen, either you have some goo on the screen that caused additional presses, or it was an issue with static electricity, or the bezel is not set right on your touchscreen. If it happens very infrequently, it was likely reason 1 or 2.
