Random... isn't?
Discussion in 'Model S: User Interface' started by gerti, Aug 30, 2016.
  1. gerti
    gerti Member
    Minnetonka, MN
    Of the music on my USB stick many songs have never been played, and some songs play quite frequently. Anybody else observing that?
    So we started playing songs in alphabetical order, unfortunately the system doesn't remember per-driver position or source (we got his' and her's USB sticks). :-(
  2. dehydratedH2O
    dehydratedH2O Member
    Silicon Valley
    That's "true random". The system doesn't track what songs have or haven't played -- it simply picks a song at random from your entire library after the current song plays. What it sounds like you're looking for is a less random system -- something that takes your library, randomizes it into a playlist in which each song only plays once, then plays that playlist.
  3. gerti
    gerti Member
    Minnetonka, MN
    It's not true random when songs a, b and c have all played 5 or more times and songs x, y and z have played never. That is called sloppy programming instead.
    I know what true random is and that ideally it would track what has played. What I submit though is that it does neither.
  4. dehydratedH2O
    Silicon Valley
    It is true random. You want random playlist generation.
  5. gerti
    gerti Member
    Minnetonka, MN
    So, if in 100 rolls your dice never shows you the 5, is that true random or a poorly fabricated dice? As said, I know very well what random playlist generation is and I also know what true random is.
  6. scottm
    scottm Active Member
    Canada
    #6 scottm, Sep 1, 2016
    What each of you want can be found on RANDOM.ORG - True Random Number Service
    ..and all the theory too.
    Suppose you have 100 songs on your memory stick, play them in this order if you like true random:
    RANDOM.ORG - Integer Generator
    But be warned! You may hear the same song more than once, and others not at all in 100 plays.
    Play them in this order if you want to hear all and don't like repeats:
    RANDOM.ORG - Sequence Generator
    Be satisfied you're getting your money's worth out of all the songs you illegally downloaded.
    • Disagree x 1
  7. gerti
    gerti Member
    Minnetonka, MN
    Libel. Look it up. I take music very seriously, and do not own illegally downloaded songs.
  8. scottm
    Canada
    That was a royal "you" not you specifically, and was a poke at anyone who does download music illegally. I don't either.
  9. BertL
    BertL Active Member
    Carlsbad, CA
    OP, my perspective is similar to yours. My MS "Random" is far less so than what I have in iTunes on my iMac and iPhone. Even with USB Phantom Playing, I tend to hear more of the same songs out of the 6K on my USB stick in my MS, than I do using iTunes with the same wide selection of tracks.
    While I could no longer get into details, and I don't want to debate the point, having been a programmer back in the dark ages, I had to write my own random number generator a couple times for applications I was involved with. IIRC, I found various seeds would make the resulting "randomness" more or less so. I simply suspect Tesla is doing something more primative for some reason that ends up selecting particular points in the same sequence more frequently than other algorithms may.
    What I do on my MS to sort of get around it, is I sometimes randomly play all the songs on my USB stick, and at others just one Genre or another. My adding that little bit of selection on my own, combined with what Media Player Random does, seems to then let me hear a wider selection.
  10. scottm
    Canada
    I recall from those programming days too, is that a sample taken from the environment makes for a good random seed.
    There are so many sensors on a model S it should be easy to grab a value from one that changes a lot and and run with it.
  11. BertL
    BertL Active Member
    Carlsbad, CA
    Very much agree. Things like DOW or HH:MM were never sufficient... Had to get down into dates+time to the milliseconds level to have a real chance of variability over time, or as you suggest, steal some other more precise variable and combine it with others to come up with a seed that is essentially unique. "Random" is just another example IMHO where Media Player works in basic use and had sufficient capability to get out the door, but isn't holding up as well in practical use several years later by a greater number of even more discerning owners. I'm anxious and hopeful to see if Tesla will use 8.0 to address many of these inadequacies (in addition to UI changes and AP improvements), but I'm not holding my breath either. ;)
  12. ArtInCT
    ArtInCT Always Learning
    Southern Connecticut
    gerti:
    When I play my USB in the S I go to browse, songs and randomly choose an alphabet letter and then choose a song.
    I am on shuffle so if I choose a song I have not recently heard, it appears that for the following session of songs, that random chooses, well they are those that were not recently played.
  13. deonb
    deonb Supporting Member
    Redmond, WA
    Look up "Birthday Problem".
    With true random selection, if you listen to 23 songs a day out of a library of 360, you're going to hear a song being played twice every second day.
  14. hanl1
    hanl1 Member
    Stamford, CT
    :) I'm sure you do.
    This means your dice is more likely to be defected than not, but it is entirely possible that you are just lucky.
    Hey someone won the Powerball! That is even less likely than rolling 100 dice without a 5 (about 1 in 82,817,974 vs 1 in 292,201,338). But of course you know this. :) I just put this here in case it is helpful to someone else here!
    Although, to be fair, I'd be surprised if they used true RNG in music shuffling logic.
  15. Dithermaster
    Dithermaster Member
    Madison, WI
    I'd prefer shuffle to random. I really don't want to hear the same song again for a while, thanks.
  16. BertL
    BertL Active Member
    Carlsbad, CA
    :) I'll take either random or shuffle, as long as it works as I expect it to. (Sorry, couldn't help myself!)
  17. scot
    scot Member
    Ashburn
    Apple had the "random" problem. People complained and complained that they weren't getting random choices from the iPod, became a Steve jobs level issue. Somewhere back in the GEN 2 days I think.
    They hired scientists to look at the randomness generators. It was worth it for other reasons, but in the end everything was definitely decided to be random. People just have a cognitive sense of repetition, pattern matching if you like, even where there is none. So they added a weighted system which lowers the chances a song may be replayed and ups random chance for unplayed songs to hit. Then people thought they had random songs...
  18. deonb
    Redmond, WA
    That's exactly NOT random. Though I think your point.
