Range degradation for S70D
Discussion in 'Model S' started by Nicola_Won, Jan 16, 2017.
Tags:
  1. Nicola_Won
    Nicola_Won We're on the cusp of an energy revolution.
    Richmond, London
    Hi all. So I have the S70D and I know that the battery is actually a 75D. My question is that I understand range loss is about 5% for the first 50,000 miles and then about 1% per annum going forward, but since the 70D is actually a 75KWh pack, would I even see this degradation since I'm only allowed access to 94% of the battery anyway? Or does the system give me a fixed 94% of what is usable of the battery?
  2. BerTX
    BerTX Supporting Member
    Texas/Washington
    Nobody knows. If they do, they aren't talking.
  3. SoccerMan94043
    San Jose
    Have 70 purchased June 2016. When I received the car, 90% charge was to 214 miles. 90% charge 7 months later flips between 211 and 212.
  4. Saghost
    Saghost Well-Known Member
    Delaware
    The logical thing would be to give you a fixed 94% of usable capacity. But as another poster said, I don't think anyone knows exactly how Tesla set this up. I guess we'll see as time goes on and limited batteries age.
  5. chillaban
    chillaban Active Member
    Bay Area
    My 70D (locked 75D) charged to 236 on delivery day and now only charges to 230 or 231. So degradation is definitely proportional to the unlocked portion of the battery.
  6. BerTX
    Texas/Washington
    The rated miles is at best an educated guess on the part of the car. It is nothing on which to base an evaluation of battery health. It is a calculation based on measurements that don't really give accurate enough information to tell if you have a problem. Just the outside temperature difference can cause the fluctuation you are reporting.
  7. Saghost
    Delaware
    Just some - I had the impression it's only the last month or two of production, but I really don't have a handle on when the switchover happened.
    The real 70 uses 14 of modules identical to the 16 modules in an 85 (the original 60s used unique modules, with fewer cells in them.)
    The 75 uses 14 modules identical to the modules in the 90, with the higher capacity cells made with more silicon in the anode.
    At some point after they switched over to the 90 and discontinued the 85, Tesla finished using up all of the older cells in 70s and quietly switched to 75s, software locked to 70.
  8. Nicola_Won
    Richmond, London
    Thanks for the responses. Looks like 70D was a good buy then given its flexibility to upgrade/potentially limited degradation.
  9. sorka
    sorka Well-Known Member
    Merced, CA
    I'm at 0.5% range loss after 33K miles and almost two years. Really hope that doesn't jump up another 4.5% in the next 8 months :eek:
  10. kavyboy
    kavyboy Member
    Spring, TX
    My S70 (no D) has always show a 90% of 218 miles, or 242 miles total Rated Miles. After a little more than a year and 10,000 miles, those values have not changed a bit until recently. I charged to near 100%, drove it down to 25 miles and hit the supercharger for a 95% charge, and back home. Now my 90% is 219, or 243 Rate Miles. I think those numbers are higher than they should be, and they are trending up, so I'm a little concerned about how accurate they are. But I'm not complaining too much, since they really do seem to translate into real world values pretty well.
  11. CuriousG
    CuriousG Active Member
    Elk Grove, CA
    Are you sure the increase in range isn't attributed to the newer firmware 2.52.22? I gained 2 miles that I lost when I went to that firmware. Confirmed due to charging to 90% that same night then updated firmware and it reported two more miles after firmware update.
  12. ChrisJ
    ChrisJ Member
    SF Bay Area (Napa Valley)
    Sounds like you both have the original 70D and not the rare software capped 75D variant.
    My June 2016 70D (capped 75D) with close to 10,000 miles, is at 208-210 miles @ 90% charge.
  13. davidc18
    davidc18 Active Member
    Ft. Lauderdale
    original 70D with 29,000 miles. just did a full charge at 234 miles. it was 240 when we picked it up.
  14. Casavant
    Casavant Member
    NJ
    S70D here... Same story. When new she charged to 240, now only to 231. 18K miles since June.
  15. kavyboy
    kavyboy Member
    Spring, TX
    Could be. That was my first big trip after the update. The more extreme charge and discharge might have affected it, too.
    Anyway, I'm happy it's where it is as long as it's realistic. I fear that it's reporting more than it really has, though.
  16. PatrickCH4313
    PatrickCH4313 Member
    Argovie, Switzerland
    Some figures with no lost (even with some additional km) after 16 months and 18'000 km.
  17. smilepak
    smilepak Active Member
    Eastvale, CA
    Mine was July 2015 S70D. These days 90% Hoover around 207, +/- 1-2 depending on days. I've set it to charge 90% or under most of the time.
    Now if I can get my battery to all of a sudden go down 150 @ 90% in the next year. I could get them to give me new batteries lol
  18. smilepak
    Eastvale, CA
    Interesting that some with original 70D can full charge 240 at some point. I can only do 231 and lately it's 223-224
  19. Magus
    Magus Member
    Midwest
    My June 2015 70D was 239 w/ a 100% charge and 237 w/ 100% now at 30k miles.
  20. BerTX
    Texas/Washington
    I realize you are joking, but to be clear, the warranty will bring your battery back to an appropriate level for it's age, not a new battery.
