Anyone who has replaced the OEM Primacy MXM4 with either the Pilot Sport All Season 4 or CrossClimate2 - how has your range been effected? Please include your tire size and type of model 3. I hope this thread will help the community make tire replacement decisions.
My car has CrossClimate tires (doesn't say CrossClimate2, so I'm guessing they are different) when I bought it 3 months ago. They look close to new. I can't really speak to efficiency since it's been so cold, but I can say that I seem to be in the normal range of what most people are posting here and the efficiency got way better yesterday and today when it get to mid 50s here.
CrossClimate (EU designed and manufactured) -> CrossClimate+ (EU designed and manufactured) -> CrossClimate2 (US designed and manufactured). The original CrossClimate was introduced back in March 2015.... manufactured, marketed and sold only in Europe in sizes typical for the market and NOT sold on this side of the pond for a few years. Eventually made it over to the US and Canada in limited number of sizes. The trend continued with CrossClimate+ and now, most recently with CC2s. Michelin just recently (early Feb 2021) expanded the size gamut of CC2s to include ones that work well with Model 3/Y 18s/19s. Many more common size/specs are still lacking. Year-round, not all-season - Tyrepress
2019 Mod3 with 18" wheels. I got 19.6K miles from the original tires. Late last year I replaced them with Pilot Sport All Season 4 which I like. I hope for only a 10% range reduction. So far it looks closer to 15% but: - I have less than 1.5K miles on the tires so they are still pretty new - Winter temps and rain are all over the place, so I really don't have a good idea what it is When I get to 2K miles, I'm going to reset one of my trip meters and take data for the rest of the year. That should give me a decent comparison with the first 19.6K miles which were 266 Wh/mi.
Of course, Michelin just announced a Pilot Sport EV tire which is supposed to have reduced rolling resistance. By the time I get my data, you probably will want that instead.
15-20% range hit? Come on, who's going to believe that. So if a car can go 300 miles with the MXM4s and then you start using the Pilot Sport All Season 4, you'll only get 240 miles? LOL And then what about the Pilot Sport 4S? That's even gripper, that must only give you 200 miles then.
I have never seen that bad and my tires have only about 1600 miles on them. In the last 2 days of 50 degF dry roads I have seen about 295 wh/mi for trips that (as I recall) are in the range of 260. That's less than 15%. My current observations are between 10% and 15% but it's not real data -- it's just eyeball vs memory which is notoriously inaccurate. I believe they will get better and, as noted above, I will start taking data at 2000 miles. Actual data for comparable conditions are the only thing that I will believe.
I have crossclimate 2 with about 100 miles on them. Seeing 10% higher w/mi consumption so far. Hoping that the range improves as the tires wear a bit more.
2500 miles in, Michelin PS A/S 4, 258 wh/mi @ 45 psi vs 247 wh/mi for 19,000 miles with MXM4 @ 42 psi.
went from MXM4 to AS 3+ and definitely lost range...a lot, although I also went from 235/18x8.5 aeros to 265/19x9.5 forged. less weight in the wheels but more in the tires to equate to nearly the same total weight overall. With this set up, it is also nearly the same diameter, so only much, much wider plus the tire. Will check pre/post and get back to you
You got a much wider cross-section tire so much more drag and significantly more rolling resistance because rolling resistance is proportional to section width also. And the MXM4 is designed to be maximum efficient while the PSA/S3+ maximum performance
When I swapped from the MXM4 to the Cross Climate I saw a 7% range hit. I am going back to the MXM4 even though the treadlife and handling are a little better with the Cross Climate.
