Range increase while parked?
Discussion in 'Model S: Battery & Charging' started by Brass Guy, Oct 4, 2014.
  1. Brass Guy
    Brass Guy Active Member
    Holbrook, MA
    After charging to 90% last night, and today driving about 160 miles, I made a stop about 8 miles from home with rated range indicating 77 miles.
    I sat in the car listening to the radio maybe 15 minutes, range indicated 76 miles.
    I finished my last errand after about an hour and started driving again. After about .5 mile, at a stop light I happened to notice 80 miles range.
    I rarely get much below 50% SOC.
    Has anybody else seen this... uhm... is there an antonym for "vampire drain?"
  2. rsanchez
    rsanchez Member
    Arizona
    Did you notice a substantial change in the outside air temp?
  3. Brass Guy
    Holbrook, MA
    Temps were consistently in the low 60's. Climate control was off all day.
  4. ABVA
    ABVA Member
    Northern Virginia
    Given that the gain was not significant, Could it be the terrain? Maybe you were loosing altitude or going downhill. Which could be determined if you have VisbleTesla installed.
  5. jerry33
    Texas
    Gain after parking happens to me sometimes. My take on why is that the only time the SOC is actually measured is on start up. The rest of the time it's estimated by calculation, so when starting the next time it may be higher or lower than the calculated number.
  6. Brass Guy
    Holbrook, MA
    Thanks Jerry. I have not seen that before, but also haven't driven far and taken a break without charging either. Your explanation sounds plausible.
