Range increase without Uberturbines?
Freewheeler
Vendor
May 22, 2020
142
135
New York
Do we know if the range of a PUP goes up if we put non-PUP wheels & tires on or is there some other factor causing the drop in range with the full package? Would like to know before I commit to a new set of wheels and tires to replace my Ubers.
glide
2,773
2,759
Rated range may go up but you may not see a material gain in real-world range.
Surely someone has done a YouTube video comparison by now.
Freewheeler
Vendor
May 22, 2020
142
135
New York
I haven't found one except an Out of Spec video using 7.5" Martians on an M3P and it was a considerable increase according to them. I just wasn't sure if it was only the wheels that reduce range, or aero due to lowered suspension, software, or a combination. If anyone has a link it would be appreciated, or maybe I'll just order a set and make one myself one of these days.
PUPpY
15
10
Oregon
You're right, it's going to depend on multiple factors, wheel and tire width, offset, weight, and construction. Suspension lowering and wheel design that affect aero resistance. Even how much weight with passengers+cargo, head vs tail winds, rain, etc. Just to say, difficult to quantify unless comparing on a track same day. As I recall, even the out of spec guy mentioned how the ambient temperature and state of charge was different at different times of their track testing day. More aerodynamic wheels help at highway speeds, and lighter wheels help at city (stop and go) speeds, but may hurt at highway speeds if they have an open design that's less aerodynamic.
Barrygold
405
413
Midwest
My rated range went up to 315mi with 20s. I didn’t have 21s long enough to compare efficiency.
Nakk
315
432
Camas, Washington
I have the 21s and have measured efficiency under reasonably controlled conditions. I am hoping to receive my 19" Martian wheels next week and I already have Bridgestone Quiettrack tires ordered. The Quiettracks are rated "Very Good" for rolling resistance by Consumer Reports. I'll test the 19"s when i get them and post the results.
Reactions: preilly44
Iceman23
65
14
NJ
When I swap my 21’s out for the 19” Gemini what should my range show now that we have the wheel configuration option on the MCU?
Ruffles
309
379
Snohomish WA
I think the decrease in range from the PUP comes from the weight of the Uberturbines and the sticky Pirelli tires. I believe the motors and battery etc. are all the same as they used to offer the stealth performance Ys and they were rated at 315 miles vs the 316 of the LR model. I've got 19" rims coming but won't really be able to test because they will have Pirelli Sotozero winter tires on them.
