Glan gluaisne
That's fine. All I was saying is that 30 10 mile trips does not equal one 300 mile trip.
Current record for LR Model 3 is over 600 miles at about 35 mph. It's pretty easy to get above the rated numbers.
Short trips in cold weather are very definitely a range killer. Both my last two cars lost a great deal of battery range when doing short trips, probably around 25% to 30% less range in short trips during the winter at a guess.
Not sure how much the heating systems (cabin and battery) use, but would guess that it's a fair bit. I've noticed that the charge point maxes out at over 7 kW when preconditioning on a cold morning, which suggests that the car's using more than that to warm up. As the car probably averages somewhere around 8 to 10 kW* for motive power, it looks as if the initial power to heat the thing could double the power consumption for a time. If the heater needs ~2 kW to keep the interior warm on a cold day, then that alone would explain the big hit seen on range.
* WAG, based on 30mph using maybe 250 Wh/mile, which gives an average power of 7.5 kW
