Yes, I have. I have followed the research/science about battery technology for quite long.If you're looking for a real-world study of well aged, high-mileage Tesla LFP battery pack performance...you're going to be waiting a while.
Have you found anything to suggest charging less than 100% is better for the LFP packs?
You've already gotten the answer, but I'd like to add that charging to 100% is hard on the battery. Don't do it unless you need that extra 27.8 miles for a trip.Hello everyone,
I bought a used (Tesla inventory) 2019 Tesla Model 3 Performance a few days ago, the car is in good shape and looks new. The only "strange" thing I found until now is the discrepancy between range and charge. I am charging in our condo SEMA chargers, and if I try to charge at 100% the range proposed is 278 miles instead of 312 miles. I asked the question to Tesla support chat they had run a remote control of my battery and they told me everything is fine and a slight degradation is normal but the car has 27000 miles. Do I need to worry?
Thanks
Seems normal for a 2019. Nothing to worry about. My 2021 is down to 299.Hello everyone,
Thanks
Of course I have read the manual. If my last name were Tesla, I would write the same, because I would want to make sure that the battery does not go down to 70% within 8 years or 160,000 km = 100,000 miles, i.e. within the warranty limits.Check your local Tesla Model 3 Owner's Manual. Here's what Tesla recommends in the US, and I don't see why it would be different elsewhere.
I've literally been there, stranded on the road with 5% reported left on an NCA Model S. After that incident the battery immediately lost a small chunk of reported capacity (on top of its existing degradation), I presume from deep discharge. At first Tesla service said the battery was still within spec, I pushed harder, then they actually looked closely at the car's logs and approved a warranty replacement.The trade off between a slightly more degraded battery is never sitting on the side of the road because you thought you had 5% left.
But as I had written, I'm asking for 20 years and 300,000 miles. Forget the manual in that case.
From a point of view of pure physics and chemistry it is possible, but unlikely that keeping the battery at 100% is best in the long run. My guess is that the optimum everyday charging target is somewhere between 80% and 95%, but I would like to know it more precisely.
I am at that stage where the range is increasing...sometimes more than is mathematically possible ! But I enjoy it so I won’t be trying to calibrate downwardsI would not think it was a deep discharge issue. First of all, Teslas Bms shut off the battery before going below the minimum voltage.
Second thing is that lithium batteries is not sensitive to low SOC. Not at all, as long as the voltage is kept above the mininum level.
The third thing is that the research shows that they also are not that sensitive to discharging below the minimum voltage. Damage could happen but it was not very much in the research and not every cell degraded from the over discharge.
I would guess that your BMS was a little off track and thought the capacity was higher than the real capacity.
If discharging to very low SOC or until the battery shut off due to low valtage limit the BMS finds put about the miscalculation and lowers the calculated capacity (nominal full pack). This will look like you lost a bit of the battery that day, but in real it was lost earlier but the BMS didnt take notice.
I have/had a similar behaviour, I only charge to 55% most times to reduce the calendar and cyclic aging. I have had a nominal full pack higher than many had in a new M3P after 15 months and no loss of range.
Last sunday I did the opposite to most others, I actually tried to get a lower max range and lower nominal full pack. I was curious about the true capacitu of the battery.
I drove the car down to -2% SOC, the next day I had ”lost” about 1.5kWh and from that about 10km range.
As I’m back to daily 55% the nominal full pack and the range is climbing back up right now, so I guess ill see the same values as before. This means that my BMS calculates the capacity slightly high and that there probably is about 1.5kWh below 0% SOC that actually isnt there.
Makes sense, quite possible the issue was already there and running it down to "5%" merely exposed it.I would not think it was a deep discharge issue. First of all, Teslas Bms shut off the battery before going below the minimum voltage.
AAKEE, in your graph...For the longevity of the battery cells, you probably need to make sure the calendar aging is quite low to keep the batterys capacity ok over 20 years.
The cyclic aging is most probably not an issue with LFP cells. I guess you will get about 200 miles on a full charge in average? That would mean that you need 1500 cycles to reach 300K mi. Not a problem at all for LFP’s, not even close.
From all Ive seen about LFP they also like to stay low for minimizing the calendar aging.
A caveat is that we havent seen research on the absolute latest LFP but the chance that a specific chemistry change totally over a night is low.
The ”step” we see on NCA and NMC is present also on LFP, but placed a bit higher up on SOC(about 70%). I guess it is the same phenomema(central graphite peak) as with NCA, only placed further up.
I would charge to 100% once a week as Tesla say, but I would not leave the car at 100%. I would select the 100% begore a drive that lowers the SOC. Also, I would set the charge to be finisched just in tine begore the drive.
As LFP is not sensitive to big cycles or 100% SOC that part is not an issue but leaving the battery at high SOC would probably cause higher calendar aging, specially in hot climate.
Yes, they show the degradation (capacity loss) from time. They leave tge cells at the SOC points and regulary test the capacity by charge full and discharge and measure the capacity.AAKEE, in your graph...
what exactly does graph (d),(e)&(f) show?...are they batteries left in storage and nothing else? Because in car use, storing for 10 months @ 50c, makes no sense.
Also in the key, all the storage times are different...so how do we compare the different batteries ?
Thanks AAKEE !! detailed as always . I will chew on this for a while...and maybe get back to youYes, they show the degradation (capacity loss) from time. They leave tge cells at the SOC points and regulary test the capacity by charge full and discharge and measure the capacity.
Capacity loss is more or less cumulative so a car that is driven 10.000 miles over the first year probably is used about 250 hours (40 moh avversge speed) for driving and maybe 300 to 1000hours when charhing.
The rest of the time, about 7000 to 8000 hours the battery do nothing else but waiting ( = the same as in storage).
So for one year with 8760h, the battery ages like calendar aging for about 85-90% of the time.
The fact that the time in the graphs is not exactly the same is not very important. The picture show the principle. One can use the 9.X or 10.X months value as the one year value for a car. Even if it would be possible to make a quite exact calculation, a car that is used is often hard to know the average SOC on, and hard to judge the average cell temp.
You can approximate the degradation for 20, 30 ir 40C, but the hard thing is to know the average cell temp(at least if hou do not have scan my tesla or something showing the cell temps.
The cell temps is not the same as the average outside temp as a car heat in the sun and the cells get heated from driving and charging.
If you still would like compare different batteries you can calculate the (for example) one year point.
The research/science use the square root formula.
If you use 1 year as the comparison, 9.3 monts is 9.3/12 of a year. The square root of (9.3/12) is 0.88. The degradation at 9.3 months is 0.88 or 88 % of the 12 month value. If the 9.3 month value is 5%, the 12 month value is 5/0.88.
We can run this on two points in the chart.
If we have 5% degradation at 1.9 months, how should the degradation look at 9.3 months? Square root 1.9/9.3 = 2.21.
The point at 1.9 months is slightly above 5, so maybe 5.2% or so?
5.2 x 2.21= 11.5%.
A look in the chart show us that the answer is not very far from 11.5%.
It is also pretty clear that you should charge to 100% before any long-distance drive and maybe also once per week, to recalibrate the battery management system. So much we know.
