Yes.Meaning when my car is sleeping in the garage am I only getting calendar aging?
And as we can not stop time, calendar aging happens all the time, as we can not stop the time.
The increased calendar aging is there for a preconditioned battery during supercharging.Or another case would be if I am supercharging and flowing energy in to a hot battery and subsequent drive after, am I only getting cycling aging at the elevated battery temperature? Or does time at temp still apply here as a double whammy.
But as preheat + charging and after heat might be only for three hours, you get 3/8760* = 0.00034 parts of one year of valendar aging at that temp.
If the sverage SOC is 80% durijg this three hours and the avg cell temp is 40C, one year would cause about 9-10 % degradation or so, which give us 0.003% of calendar aging induced degradation for tha three hours.
Not heating the battery might cause lithium plating which is not goig at all. Of course Tesla counters this by reducing the charging speed but it sure looks like non heated batteries suffer from that.
I always precondition.
A preconditionen 48-50C hot battery will suffer the least from supercharging.
The other option is to not supercharge.
*One year is 8760hrs
No, calendar aging is still present and you add a little part of a cycle each day with sentry mode on.Another case would be if I have my car in garage and sentry mode on, car is pulling some load, am I only getting cyclic aging?
Obe year of constant sentry would perhaps add 20 Full Cycle Equivalents each year but these are very nive to the battery as it is s very low current ( C-load)
There is calendar sging during cyclic testsSeems its a blended aging effect but wonder if there is even further best practices I can do to reduce any aging further even beyond lowered SoC, especially where I live in the hot summers. The data research always run tests on calendar aging or cyclic aging but not together and its impact, if any.
Some tests specify the difference.
As batteries are quite good tou vcan not perform cycle and calendar aging tests in the same rate as the cars use the battery. It would take as long as it takes for a EV to break the battery.
Calendar aging is tested for 1-2 years and then the commonly accepted formula for calendar aging is used to project the calendar aging further on.
Cyclic agijg is performed in a much faster way than real driving (many cycles each day), minimizing the impact from calendar aging.
Some researchers combine this by deducting calendar aging from the cyclic test and then combine the net from cyclic with the calendar aging.
Then we get graphs for how a battery will hold up long term.
Each of this, of course show us that low SOC and small cycles wins tge long life contest.
