Thanks alot, how do you know this all? I still have to read this a few times before I fully understand I guess.
(Why I can only seem to use under 42kWh extrapolated, and how do I read the nominal capacity?)
I am not so sure about original 100% full, because I didn’t pay as much attention to it. Might look back at early pictures of me being happy in the car, maybe I have some with the range numbers.
I don't "know" anything. I'm just kind of triangulating based on data gathered from various sources:
1) EPA documents which provide exact data on DC and AC efficiency and battery capacity.
2) peoples' reports from tools like ScanMyTesla which have confirmed and refined my understanding of how things work.
3) my own experience of how the trip meter work, how the rated miles work, etc.
4) Screen captures of the Energy screen in various vehicles which allows calculation of the charging constant.
It was really confusing for me at first, but in the end it is fantastically simple.
Pack capacity is: Rated Miles @ 100% * Charging constant for your vehicle.
Note 1: You cannot use this formula to calculate kWh remaining, except at 100%.
Note 2: This formula may underestimate pack capacity for brand-new vehicles. It is only accurate for sure once loss of capacity is visible.
Charging constant info:
2020, 2019, 2018 Model 3 Battery Capacities & Charging Constants
Note: The SR line (not the SR+) is incorrect. I had incomplete data. I will correct this soon.
Note the charging constant is important, but frankly it is confusing. The main (and only) value of it,
is that it can be directly calculated for any vehicle from a picture of the Energy -> Consumption screen. And then everything else flows from it. For your vehicle it is ~219Wh/rmi. So your full pack is 213rmi*219Wh/rmi = 46.6kWh.
I prefer to refer to the discharge constant, since that's what really matters:
The discharge constant is 4.5% less than the Charging constant. That's because 4.5% of the full pack energy is below 0 (the unusable (bad things can happen) buffer)! So that full rated range displayed is only 95.5% of your full capacity. Each rated mile displayed contains a certain amount of energy, equal to this discharge constant numerical value.
The trip meter constant is subtly different than the discharge constant - it is about 2% less, because for unknown reasons, the trip meter seems to fail to account for about 2% of energy usage.
So that is where the factors of 0.955 and 0.98 come from. So if you want to see what the maximum value you could see on the trip meter was,
assuming you stop at 0 rated miles and don't go into the buffer, you would take your full pack capacity and multiply by 0.955, then by 0.98:
213rmi*219Wh(BMS)/rmiEPA*0.955rmi/rmiEPA*0.98Wh(trip)/Wh(BMS) = 43.7kWh (trip)
