I have not fully undertand:
I was thinking you were charging the car to 55% at night and START to use the car immediately after the end of the charge (or as fast as you can).
Then you say that you had to change habit letting it (instaed) sleep another 1,5 to 2 hours before to use it to go work?
What I wanted to say with my posted graphs (here the update one at today) is that it seems IMPOSSIBLE to determine the ACTUAL kWh capacity even having SMT, because the flutuations are too big.
In my example, which is the correct kWh capacity of my march 2021 82.1 kWh "Full Pack When new" Pana Battery? 73,8-73,9 (the february level after 11 months?) OR the 77,7-77,8 kWh (the January level ) Or the 77,8 (the level of NOW)?
OR probably it's something in between? (76,00kW?).
If someone ask to me, which is the level of degradation of your car battery after 14 months? I have to reply : " Im not sure, it's Between -2,6% to -8%"
What I wanted to say is that we are nerds enough to look at the fraction of the Watts, and using millivolt precision to judge things, then we have results where there are 4 kWh difference between readings.
