Calendar aging reduce over time. (Reduces with square root of time).
If first year is 7% (just an example), you reach (the double )14% after four years and double it again to 28% after 16 years.
If you have an low average like 30-35% (like I do) you will not loose more than about 5% the first year.
5% after first year.
7% after year two
8.7% after year three.
10% after year four.
20% after 16 years.
We need to differ between BMS Range and true range (or BMS estimate of battery capacity and real battery capacity)
You can calculate the bms estimated battery capacity via the energy screen.
Search for this, but in short (in energy screen) [estimated range x consumption divided by SOC = total battery capacity, as estimated by the BMS.
But the on screen range is closely connected to this so this can be calculated from the max range as well.
The real range or capacity can differ from the BMS value if the bms is aff from the real capacity.
Only if the cabin temp exceeds the limit and that option has been selected to on…
Nope.
Also, the optimum battery temp during cycling is higher than 25C so for cycling 25-35C is good.
Its during sleep(battery rest) as the cell temp is better kept low.
I do not know, would not gues that.
Yes, holiday trip with my family. I hope to miss the rain
Just a few days, rented a Tesla and then the nice nature northwest of Vegas before San Fransisco.
