In the Model Y EPA Application, Tesla listed the dynamometer set coefficients for the three wheel and tire combinations available for the 2020 Model Y Performance. These coefficients are used to set the dyno for the EPA testing. They tell the dyno how much force to use to mimic the aerodynamic drag on the vehicle because it is stationary during the test. The coefficients are on page 20 of this document: https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=49398&flag=1.
I plotted just the road load force in this thread, but the below graph shows the percent difference in efficiency or range when comparing the three options.
It is important to note that this data is only applicable for constant speed driving, such as on the highway. When accelerating and decelerating, heavier wheel and tire combinations will use more energy that is not included here. That means that if city driving efficiency were added to this highway driving efficiency data, the disparity between the options would be a little larger.
Also, using different tires will affect these results.
To summarize, at a constant 75 mph [121 kph]:
- Range with 21's will be 7% less than with the 20's
- Range with 20's will be 7% less than with the 19's
- Range with 21's will be 14% less than with the 19's
