Range mode is "sticky"
Discussion in 'Model S: Battery & Charging' started by ggr, Dec 1, 2012.
  1. ggr
    ggr Expert in Dunning-Kruger Effect!
    San Diego, CA
    Yesterday I charged in Range mode, drove around, came home, and plugged it in. I assumed that, like the Roadster, it would reset to standard mode. But it didn't! It charged again in range mode. I'm pretty sure the only other time I charged in range mode, it did reset itself. The only thing I think I did differently this time was that while I was still in the car, I popped both the trunk and the charge port door. When I just went to turn off range mode, there was a pop-up warning me about too much use of range mode, and did I want to switch back to standard, but this was *after* it was done charging!
    Weird corner conditions in the software, I guess.
  2. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    The Rav4 EV does this also. I think it is a mistake!!
  3. Charged_Up
    Charged_Up Member
    Miami, FL
    funny, I just discovered this error today as well - range charged yesterday in Model S, came back and plugged it in assuming it would revert to standard, but it didn't. Should be an easy fix.
  4. Cottonwood
    Colorado
    Yes, range mode in the R resets automatically, and in the S, it is sticky. I agree, I prefer the auto reset method in the R.
  5. cinergi
    cinergi Active Member
    MA
    Yes, it's sticky. I did ask ownership about that... but in the meantime, I noticed if you do it ~3+ times in a row, you'll get a message on the screen reminding you you're in range mode and asks if you want to shut it off.
