TEG
Teslafanatic
- Aug 20, 2006
- 21,719
- 8,690
Yes, that sort of does make sense. The earlier PEM perhaps had a syncronous switching limit at a lower RPM, so the intentional fall of the torque curve had to start earlier.
Now I still think that the inverter must have a fairly direct relationship between frequency and RPM, so I think the drop-off is due to intentional voltage drop as they rev the eMotor above syncronous speed. The ESS might even be able to keep delivering the max voltage, but the IGBTs couldn't handle switching that voltage that fast. So they either have to hold the eMotor at syncronous RPMs, or start reducing voltage as they ask the IGBTs to switch faster.
(At least this is what I am starting to think)
I think the torque/flux control model probably just does some conversion to frequency/voltage, but there are some subtle "weirdnesses" in the way you can send power to the motor. I recall some mention of "eddy currents" in the magnetic fields that perhaps can be optimized. I am guessing that the torque/flux control model lets them control the power flow a little more carefully based on the way the motor operates. All those Feynman lectures maybe start to come into play now.
(again there are experts that could confirm or deny all of this, but they are probably too busy designing motor controllers to "chew the fat" over here)
